Old 03-27-2007
wumhenry is on a distinguished road
reassembling Lewmar ST40: stumped!
Last weekend I partially dissassembled a Lewmar ST-40 2-speed winch for annual maintenance. Never having done this before, I was awed by the internal complexity of the thing and decided I'd better put it back together because there wasn't enough time left to finish the job before dark.
I was stymied when I tried to replace the feeder arm. The goldang collets, which fit into grooves in the spindle, stuck out too far, so I couldn't seat the feeder arm. Turning them upside down and swapping their positions didn't solve the problem. I finally removed the collets and replaced the feeder arm and end cap sans collets to keep the rain out till I figure out how to solve this problem.
Can anyone here help me with this?
Old 03-27-2007
Sure...if you look inside the slot where they go, you can see that inside the slot there is another slot...it goes there..try rotating the winch a little, its a litle difficult sometimes, but you have to find the slot.
Use a little grease to keep them in place while you do.
GO HERE open PDF file its all there!!! Look up in fitting winch and service manual...You'll understand what I mean with the slots.
Hope it helps
Old 03-27-2007
Thanks, Giulietta, I'll go out there and give it another try.
I didn't see a link to the service manual in the website, though.
Old 03-27-2007
Be careful what you grease... some parts, like the pawls really shouldn't be greased at all...but should have a light machine oil used on them, as they need to move as freely as possible. I haven't taken a winch apart in a while, so I don't remember if the collets are supposed to be greased or oiled...
wumhenry- Try this link
Old 03-27-2007
Its there, where I told you..but SD shows it easier..
Thanks SD. Those 2 parts you can grease just to keep them in place.
Old 03-27-2007
hellosailor's Avatar
Try http://en.lewmar.com/support/index.aspx?link=4 that's the Lewmar key page for CAD drawings. They have drawings of most/all of their winches, sorted by series.
Old 03-27-2007
HS-
Unfortunately, you'd need a program capable of opening an AutoCAD drawing file, which most people don't have, to use the files on that page.
Old 03-27-2007
He has all he needs on the links I gave him....
Old 03-27-2007
wumhenry-
BTW, the service manual for the winches is on the page that Giulietta linked to. It is directly under the heading of
Winches
and is labeled:
How To Service Your Ocean Winch
His post was pretty dead on... you just need to read the page a bit more closely.
Old 03-27-2007
Duhhhhhhh
Servicing older lewmar winch zeilfanaat Gear & Maintenance 3 06-06-2011 02:58 PM
older lewmar winch parts windancer1 Gear & Maintenance 2 09-11-2009 06:10 AM
Lewmar 46-ST TexLex Gear & Maintenance 7 03-13-2009 05:35 PM
LEWMAR winches, mod 44; 1980-1983 Salescalls Gear & Maintenance 1 05-16-2006 09:37 PM
Lewmar port screens bista Gear & Maintenance 0 08-15-2001 06:33 AM
