-   -   matching steels and galvanic corrosion (http://www.sailnet.com/forums/gear-maintenance/30758-matching-steels-galvanic-corrosion.html)
khbritten 03-27-2007 08:46 PM
Anyone know if I will have a problem with stainless steel abutting regular steel in a damp and salty place?
JouvertSpirit 03-27-2007 09:04 PM
The less noble metal will seek nobility. I hope that doesn't bring politics into this thread :)
sailingdog 03-27-2007 10:16 PM
The steel will get eaten up as a general rule, since it is less noble than the stainless steel.
sailaway21 03-28-2007 12:55 AM
Your "problems" should be minimal.
RickBowman 03-29-2007 09:16 PM
khbritten,
What type of stainless steel are you discussing, as this could make a difference.
sailingdog 03-29-2007 10:20 PM
khbritten-
Just be careful if the stainless is under high load. 304 stainless tends to have serious problems with chloride induced corrosion and can fail pretty unexpectedly. You'd be much better off using 316L stainless for both pieces.
