04-02-2007
If the paint is flaking, and you sanded it prior to painting, it usually means that someone along the way before you did a bad prep job, or that there are just too many layers of paint on the bottom. Paint only sticks to what ever is just beneath it.... and if you get enough layers, the inner layers won't be able to support the outer ones...and will flake off.
Sanding the hull down until you get to the gelcoat is one way to insure that whatever you apply will stay stuck. But if you go down to the gelcoat, you'll probably want to barrier coat or prime the bottom before continuing.
