need to fab new companionway hatch - Page 2 - SailNet Community
post #11 of 47 Old 03-31-2007
Nightowle-
Personally? I think wood products exposed to the outdoors are just a way of ensuring jobs for maintenance staff. I'd use 1/2" plexiglass instead for a zero-maintenance solution that also allows more light down below. WAY more light.
Not clear plexi, but translucent plexi, either "milk white" or other colors available, or plain transparent smoked if that suits you better. If you want extra privacy but don't want the translucent stuff, you can use the plain smoked and just have one side sanded or sand-blasted, the abrasion will make it impossible to see through.
Any grade of plexi is strong enough for this application, you'd want to do a little rounding and polishing to take off rought/sharp edges, or have a plexi shop fab them to match your old boards, it should be a fairly simple job. I wouledn't worry about scratch- or UV- resistance for this application either, but if you want to splurge you can ask for a better grade of plexi with that in mind.
And they don't all have to be the same, i.e. you can make the lowest one clear (so you can see out) while keeping the top ones translucent to keep prying eyes out.
hellosailor is offline
post #12 of 47 Old 03-31-2007
Freesail99's Avatar
I just got back from my boat and I was thinking about this. What about starboard ? You would never need to do anything to it, zero maintenance.
Freesail99 is offline
post #13 of 47 Old 03-31-2007
Starboard should also work, sure. How's the price compare to plexi in 1/2" material?
post #14 of 47 Old 03-31-2007
Freesail99's Avatar
One other feature about starboard over plexi is security
post #15 of 47 Old 03-31-2007
Get some teak boards and route the edges down to the 1/2" you need. Good looking end strong.
rchrdcoe is offline
post #16 of 47 Old 03-31-2007
HelloSailor-
I wouldn't use Starboard, because it doesn't really have the tensile strength that ABS, Lexan, Polycarbonate, Acrylic or Plexiglass have. If you look at the commercially made Starboard dropboards, they're actually laminated with a stainless steel crossbar as reinforcement.
Starboard is far weaker than the other materials, and the manufacturer says it shouldn't be used as a structural material.
Yotphix-
I meant Lexan, but in many ways, ABS, Polycarbonate and Lexan serve very similar purposes..
sailingdog is offline
post #17 of 47 Old 03-31-2007
Wandering Aimlessly
PBzeer's Avatar
One other thing about Starboard, it's as expensive as teak.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #18 of 47 Old 03-31-2007
T37Chef's Avatar
FYI...
Welcome to Exotic Lumber Inc
Unfortunately they're 2 minutes from my home
Shawn
T37Chef is offline
post #19 of 47 Old 04-02-2007
Helms ALee!
tenuki's Avatar
lexan I'm guessing.
tenuki is offline
post #20 of 47 Old 04-02-2007
Haguesail's Avatar
I had a Lexan companionway door that was crazed and cracked, replaced it with marine plywood cut to shape, with a teak louvred vent set in the upper middle (with brass screws). The vent improves ventlation over the plastic, and the door looks great when varnished and finished with a nice hand-hold.
Chris
Monnickendam, NL
'88 Colvic Countess 33
Haguesail is offline
Companionway hatch for E-27? captainbrad Ericson 5 09-25-2011 10:46 PM
Companionway Hatch Replacement danohayes Gear & Maintenance 9 10-23-2008 09:46 AM
Wauquiez Hood MK I Companionway - pros and cons garymcg Boat Review and Purchase Forum 0 10-17-2006 02:53 PM
Wood vs. Plexi - Companionway Hatch Boards lightyear22 Gear & Maintenance 7 03-16-2006 09:06 AM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
