03-31-2007
If you've properly potted the holes, then the water coming in is a nuisance, but not a major threat...
One thing that can help to really keep the holes from leaking is after you've potted them and let the thickened epoxy dry, and drilled the holes for the fasteners... go back over then holes with a countersink bit, and use it to chamfer the edges of the hole on all of them.
Then, when you add the sealant, it will have a space to form an o-ring seal of sorts and that can help make the seal much better, even if you snugged the traveler track down so hard that it has squeezed out most of the sealant, a bit will remain in the countersunk areas...
