Old 03-31-2007
Sabreman's Avatar
Sabreman will become famous soon enough
Bronze vs. Stainless Shafts and Marine Growth
For many years I've has bronze shafts. We keep our boat(s) on the Chesapeake and by July there are a fair number of barnacles on the shaft and prop. Last year, I replaced the shaft with one of stainless steel. I swear that the new shaft accumulates less growth than the old one. Since I kept the old bronze prop, I was able to compare the growth and it really looked like it had more growth
Questions:
1. Has anyone else experienced reduced growth on stainless (or is it my imagination?
2. Why would bronze allow any growth at all considering it is "..at least 89% copper..."? My bottom paint has less copper and barely anything grows on our (boat) bottom. I know that paints have additives, but the active ingredient is copper. See the related link:
Silicon Bronze - Mechanical Engineering, Mechanical Engineer, Material Engineer, Material Engineering,Manucaturing Engineering
Sabre 38 "Victoria"
Old 04-02-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Copper-laden anti fouling paints work by constantly leaching biocide (cuprous oxide), thereby retarding the growth of organisims. A bronze prop shaft does not do this. It is a good question however. Some boats still use copper sheathing as an effective anti fouling solution.
"Clean bottoms are FastBottoms"
Old 04-02-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Sabreman is certainly right about the bad season last year in the Chesapeake with alga growth and barnacles. When pulling the boat two weeks ago I found out how bad it was, in fact I am not sure the Auto stream prop would have worked with so much build up. I have applied a zinc paint by Interlux in hopes that it will reduce the problem to a minimum?
Has anyone had good results with something else?
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 04-02-2007
Sabreman's Avatar
Good thought, Fstbttms. If the shaft constantly leeched copper, there would be nothing left to it after a while. I suppose the silicon that is added to the bronze really hardnes it.
Sabre 38 "Victoria"
Old 04-02-2007
I know some people coat the prop with either anhydrous lanolin or Lanocote... I don't know how well it works though... You could also try to coat it with some of the new dry film lubricants, like McLube SailCote... and see if that helps.
