eng - trans problem help!!!!!! - SailNet Community
post #1 of 3 Old 01-21-2002 Thread Starter
have a 30 pearson and it has a yan-mar eng and odd ball japanise trans.. after extracating the pair from the eng compt i find that i am unable to seperate then. so i guess that the splined shaft is fused in place. any ideas????? firemanbob
firemanbob is offline
post #2 of 3 Old 01-21-2002
RichH's Avatar
Yanmar usually applies a transmission from its subsidiary Kanzaki and with gears, etc. from Hurth Transmission.
Typical Yanmar transmission dissassembly requires a special set of tools to remove the output shaft nut from the output shaft.
For example the 2QM20 requires special wrench #177099-090910 and special coupling lock #177099-09020 .... this will get the output coupling disconnected, then its a simple dissassembly once you get the shifting fork disconnected. For a 3QM30: special wrench #177090-09100, and coupling lock #177090-09140.
Be careful, as the Kanzaki Transmission requires a lot of special tools, etc. to properly disassemble,etc.
If you''re located on the East Coast, contact Mack Boring Co. in NJ who is the master distributor for Yanmar for the eastern USA ..... also get the service manual, to make your life easier in itemizing the special tools needed, the sequences and other specs. What you are about to undertake is a near impossibility without the special tools required.
RichH is offline
post #3 of 3 Old 01-30-2002 Thread Starter
I fixed the last problem. now i am unable to remove the damper plate from the flywheel.. rusted tight... I was told that I may as well just rip it off and replace the plate, which is I understand is about $100.00... what do you think??? firemanbob
Catalina 34 Starting Battery Problem Garytami Gear & Maintenance 10 06-04-2015 03:40 PM
Trans Atlantic US to Europe Curray Crew Wanted/Available 0 03-07-2004 03:14 PM
Funny Electrical problem Bruceo1 Gear & Maintenance 2 12-15-2003 06:01 AM
Head Problem bjoc2314 Gear & Maintenance 3 04-23-2003 09:16 AM
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 10:59 AM
