01-24-2002
Senior Nappy Headed Ho
Navigation calculator
You don''t need to spend any money if you have a simple calculator with the four basic functions. Her is how simple it is to convert decimal degrees into to degrees, minutes and seconds. For example take the position 42.45894 degrees. Drop the whole number and multiply the numbers to the right of the decimal point by 60 and you get 27.5364, so 27 is the minutes. Drop the whole number and multiply 60 by the numbers to the right of the decimal point and you get 32, this is the number of seconds. The actual product of the last calculation is 32.184 so you round to the nearest whole number. The correct answer is 42 degrees, 27 minutes and 32 seconds. Send me the $50.00
