Major Oil leak - Page 2 - SailNet Community
post #11 of 15 Old 04-02-2007
Faster-
I doubt this is the problem, as the boat was at the dock the second time... Also, sounds like they hadn't even made it out of the marina the first time around.
D'oh.... note to self: Read all the damn posts... thanks SD
Faster is online now
post #12 of 15 Old 04-02-2007
LOL... and sometimes refreshing the thread helps too.
sailingdog is offline
post #13 of 15 Old 04-02-2007
"then screw it on by hand pretty tight but not as tight as you could make it. "
After a similar oil spill my boatyard tells me that Yanmar now requires that filters be tightened mechanically...more than by hand.
bhcva is offline
post #14 of 15 Old 04-02-2007
Does the oil filter housing look at all distorted or swollen?
I am not familiar with Yanmar, but almost all engines have an oil pressure relief valve that is supposed to open & send extra oil back to the oil pan if too much pressure develops.
If this valve sticks it can cause the oil filter to swell up & distort & create a leak where he filter attaches to the block. If this is to occur, it probably will be on a cold start when the oil is thick.
Often the pressure relief valve is part of the oil pump, but it may be a separate valve on the engine, as I said, I am not familiar with Yanmar.
dleit is offline
post #15 of 15 Old 04-02-2007
moderate?
camaraderie's Avatar
bhcva..thanks for the update!
camaraderie is offline
rain leak in MacGregor 26x newuser Gear & Maintenance 9 06-10-2015 10:54 AM
Mast Step Leak Uncle General Discussion (sailing related) 8 02-28-2007 10:29 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 12:41 AM
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 08:00 PM
