04-02-2007
You'd be better off using a diaphragm-type bilge pump, like a Whale Gusher. Major advantages, it moves a lot more water, it can run dry without many issues, and it will pass some debris and small objects, which most of the sink type faucet pumps will not. They also make foot pumps for galley sinks that are smaller diaphragm pumps that would also work quite well.. They're even better in some ways, even though they have smaller capacity, since you don't have to touch them with your hands... you could, in theory, be pumping the shower sump while showering...
