-   -   Glazing lexan and painting aluminum (http://www.sailnet.com/forums/gear-maintenance/31036-glazing-lexan-painting-aluminum.html)
Alden68 04-02-2007 08:26 PM
Looking for recommendations for the proper material to glaze lexan into a teak deck hatch. Also, while I'm at it....can anyone recommend a spray enamel that is tough enough to handle the marine environment??
I am in the process of refinishing an aluminum windlass body.
Thanks
sailingdog 04-02-2007 08:39 PM
They have a spray epoxy enamel that is used for appliance paint that would probably work quite well for you. They've used it down on some of the boats at my marina. I don't know what it is called though.
The teak is going to be the problem... Teak is an oily wood that many sealants have trouble bonding to. I would try one of the butyl rubber based gasket tapes that are commonly used in the auto industry rather than a marine sealant. The only sealant that seems to work well with teak, other than 5200, are the polysulfide-based ones, and polysulfide will attack the lexan IIRC. Try something like this.
Alden68 04-02-2007 08:47 PM
SD - Thanks for the Hart Supply link. Not to far out of the way for me. They should have exactly what I need.
I'll check out some appliance places by me and let you know what I find....
Thanks
sailingdog 04-02-2007 09:10 PM
Alden-
The guys over at Hart are pretty good eggs... I think that stuff will work pretty well, but you should check with the guys there. BTW, where are you sailing out of/located. I'm down in Fairhaven, on the Acushnet river...
Alden68 04-02-2007 09:20 PM
I will definitely check with them to get their input. I sail out of Salem harbor but I travel back and forth to the Cape quite a bit so Hingham is an easy stop.
Is the Acushnet where the USS Massachusetts is?
sailingdog 04-02-2007 09:32 PM
Nope, you're thinking of Battleship Cove, which is in Fall River.
If you need some assistance drop me a PM, since I live/work up in the Boston area, so you're probably not too far from me.
Alden68 04-02-2007 09:36 PM
Great...I appreciate that.
Thanks.
