Old 04-07-2007
Quickstep192 is on a distinguished road
New outboard mount
On my Quickstep, the 8hp outboard is mounted on a piece of teak about 20" long by 8" high by about 3/4" thick (see photo). Where the bracket clamps onto the teak, there's an additional piece about 4" high by 6" wide by 3/4" thick that doubles the thickness in that area. I've never felt good about the strength of that arrangement and as part of a plan to eliminate some of the teak from the boat, I'm thinking about replacing it. If I made a replacement by laying up multiple layers of fiberglass cloth with resin, would that be strong enough? Could I make it by encapsulating a piece of Coosa board? Any input is greatly appreciated.
Old 04-07-2007
Quickstep-
While I'm not too familiar with Coosa board, I would recommend that you use marine plywood instead. I believe Coosa board has a foam core and is not going to have the compressive strength or tensile strength that marine plywood is going to have. I also believe that marine plywood would be less expensive than Coosa board.
I would make the replacement outboard mounting board out of two pieces of 1/2" plywood, since that should have more than enough strength to support an 8 HP outboard.
I would make it by laminating the two pieces together with epoxy, and then screwing them together. After putting the screws in, I would glass over the whole thing using kevlar* cloth, to give it abrasion resistance and to encapsulate the wood and prevent water from causing any problems with it in the future.
When you drill the mounting holes, I would drill them oversized and fill them back in with thickened epoxy, to prevent the water from intruding through the fastener holes. You should paint or varnish the board to protect the epoxy from UV-degradation.
* If you're going to sand the board to finish it off, use a final outer cover of fiberglass, as kevlar is a bastard to sand—basically, it doesn't, since it is so abrasion resistant, it shreds and leaves little spikes sticking up all over instead.
Outboard Motor Mount bsteele Sabre 0 05-22-2006 07:30 AM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
outboard Motor Mount reid5009 Gear & Maintenance 3 04-12-2003 07:29 PM
