Old 04-08-2007
pmoyer's Avatar
"Quack, damn you."
pmoyer is on a distinguished road
Send a message via AIM to pmoyer
Guest ConnectCharge plugs?
To go along with the "undersized charger" thread....
I am getting a Guest 20A/2b charger, and it comes with their "ConnectCharge" plug pre-wired. I already have 110 shore power coming aboard, but it's distributed directly to cabin outlets. There are no connections (yet) between the inbound 110 and the 12v system.
Has anyone wired one of these up before? Will I need to install an new receptacle in the cockpit for this connection, or can I somehow wire it into the existing 110 connection?
Sorry for the silly questions....
Cheers!
Phil Moyer
S/V Puddleduck
Columbia 26K
Old 04-08-2007
Of course, you can wire it up directly, but that will generally involve chopping off the "ConnectCharge" plug and may or may not void your warranty..
Why would you setup a receptacle in the cockpit for it... just wire to the existing shore power system. If push comes to shove, you can always get a "ConnectCharge" receptacle, and add that to your existing 110 AC side and then plug the charger into that... Doing it this way, you can install the receptacle near where the charger needs to go and put it on its own breaker.
Old 04-08-2007
pmoyer's Avatar
"Quack, damn you."
Ahhhhh, I think I'll have to do the latter. The ConnectCharge receptacle looks exactly like the receptacle in the cockpit for shore power, complete with waterproof cap. I suppose I could install the ConnectCharge receptacle between the lazaretta and the battery compartment, and then us a 20A cable to connect the receptacle to the existing shore power system.
I suppose I could also wait for the charger to arrive, and see what the installation instructions say. That would require patience, though, and I'm soooo excited about getting out on the water! Of course, it's 40 degrees F with a 20kt wind, and there was ice (!) on the boat yesterday. I'll just cool my jets and work on some other projects until the new wiring arrives.
At least my wife works at an industrial manufacturing facility, so I can get my Group 24 batteries 25% below list by ordering through them!
Cheers!
Phil Moyer
S/V Puddleduck
Columbia 26K
Old 04-08-2007
Glad to help...
Guest Jumps Off NYC-Bound Carnival Cruise Ship (CBS 2 New York) NewsReader News Feeds 0 05-28-2006 09:15 PM
Teak trim plugs and varnish ilnadi Gear & Maintenance 1 05-22-2006 12:27 AM
Diesel Problem: Glow Plugs in a Nanni (Mercedes) RichH General Discussion (sailing related) 1 04-21-2003 09:06 AM
european shore power plugs kimberlite Gear & Maintenance 2 03-05-2003 06:02 PM
