Blogs
User Name
Old 04-09-2007
PrarieRose PrarieRose is offline
PrarieRose is on a distinguished road
Older Lewmar Winches, Maintenance
I have older (1977) # 40 two speeds and a 25 and 16. All of them are slightly different from any schematic that I can find. There is a bronse cog on top of the spindle post that wont allow the removal of the bearing races. how do I dissassemble these winches. The 16's are quite simmilar to the drawings, except that there are no nylon keyways to be removed to take out the spinal post. Thanks for the help everyone!!!!
Old 04-10-2007
mike dryver mike dryver is offline
mike dryver is on a distinguished road
google lewar winches and go to the austrailian winch co (arco) i think it is that is lewmar and you can down load pdf schematics. they should have yours as they have most if not all. i have early barients and they have all parts for these. you can e-mail them for any info you need, and or parts.
Old 04-12-2007
Lecy Lecy is offline
Lecy is on a distinguished road
Lewmar and Australian Winch Company are completely different companies. Lewmar has a website,
Lewmar Home
and they show schematics for modern winches. They also list Master Parts Distributors by geographic regions. The Master Parts Distributor for your region should have the schematics for older winches. Good luck finding the info you need.
Old 04-12-2007
Gary M's Avatar
Gary M Gary M is offline
Gary M is on a distinguished road
I had some 1977 vintage Lewmar winches on my last boat and if I remember right they had to be removed from the deck to get them apart. Sorry but I am pretty sure that is what you have to do.
One advantage of getting them off is that you can work on them in a work shop and not have to worry about dropping bits in the water.
Also it is likely time to rebed them any way.
Gary
Display Modes
vB code is On
Servicing older lewmar winch zeilfanaat Gear & Maintenance 2 05-12-2004 10:46 PM
Reducing Exterior Maintenance Sue & Larry Gear and Maintenance Articles 0 10-15-2003 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
older lewmar winch parts windancer1 Gear & Maintenance 1 05-26-2002 12:28 PM
Winches SailNet Miscellaneous 0 08-23-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
