Shore power question - Page 2 - SailNet Community
post #11 of 24 Old 04-12-2007
Idiens-
Single phase, which is what most countries use IIRC.
Cam's point about the frequency is a good one... Some electronics don't like the change in frequency...
sailingdog is offline
post #12 of 24 Old 04-13-2007 Thread Starter
Omatako's Avatar
Idiens
The issue actually is that I don't want to keep my system at 110v because then I'm tied to 110v appliances and they're not thick on the ground in my part of the world. It means that everytime SWMBO wants a new hairdryer it has to come from the US. Thanks for the thought.
Cam
Whilst I haven't examined the matter minutely here at home, I tend to go with Idiens inasmuch as the appliances in Aus and NZ are dual frequency. I'll need to just do a little homework on that but I'm sure that's correct.
SD
An interesting thing that is often done with the three-wire sustem here is to use the earth line to transmit data around the house. I haven't personally tried it but I believe it works quite well.
Guys thanks a lot for the responses, I reckon it'll be good so what I'll do is make sure my insurance is up to it then plug the thing in.
Andre
Omatako is offline
post #13 of 24 Old 04-13-2007
Omatako-
They do that here in the US as well, with things like computer networking gear, and a few other things.
I see your better half is referred to as SWMBO—She Who Must Be Obeyed...smart man... She has you well trained.
post #14 of 24 Old 04-13-2007
Household power in the US is two 110V legs. Each leg to ground is 110V and leg to leg is 220V. House wiring is 3 wire for 110 and 220 with 110 being hot, neutral and ground and 220 being hot, hot, ground. Of course ground and neutral are tied together at the power box.
If you have a US GFCI recepticle installed you might want to replace them with local ones and they have different (better, lower current and faster shutoff time) standards outside the US.
As far as 3-Phase power you usually measure between the phases for voltage vice ground. Hopefully we don't see that on sailboats!
arghhh is offline
post #15 of 24 Old 04-13-2007
arghhh-
If you need 3-phase 240 VAC power on your sailboat, it better be a really big bastard.
post #16 of 24 Old 04-13-2007
arghhh-
SD,
Right now the boat I'm on has 440 VAC 3 phase power and 3 4500KW gensets.
arghhh is offline
post #17 of 24 Old 04-13-2007
ebs001's Avatar
Hold everything, while the wiring will be fine to handle the current with the 220 volts any load connected to it will have to be rated at 220 volts-to name a few that are hard wired and have to be replaced : battery charger, hot water tank , inverter and any thing else that's hard wired. All receptacles should be replaced with NZ receptacles rated at 220 volts. If you just connect 220 volts to the existing hardwired equipment it will fry. Ohm's law rules. E=IR. R remains the same so if you double E(volts) you double I (Amps)
ebs001 is offline
post #18 of 24 Old 04-13-2007
Of course, but he did say appliances aside. I think he was more worried about the wire itself as he knew he would replace all the appliances with their NZ equivilents.
arghhh is offline
post #19 of 24 Old 04-13-2007
Originally Posted by arghhh
SD,
I'm betting you need more that a travel lift to haul it..
post #20 of 24 Old 04-13-2007
ebs001-
But generally each piece of equipment uses the same amount of power, whether it is a 240VAC or a 120VAC... a hair dryer will be about 1500 Watts... so P=EI, so if you double the voltage, to get the same power, you halve the amperage.
Re: Shore power cord question NewsReader Mass Bay Sailors 0 01-30-2007 07:15 PM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 07:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 07:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
