Blogs
User Name
Old 04-11-2007
Gulfislander's Avatar
Gulfislander Gulfislander is offline
Gulfislander is on a distinguished road
Wireless??
Hey All,
I am looking to upgrade my old electronics (speed and depth). I was initially planning to install the the Raymarine ST60 electronics package (speed, depth, and wind indicator). I was chatting at the boat yard yesterday and heard that the wireless electronics package out there is easier to install. I was told that the the increased cost of wireless is off set by the savings in labour cost and hassle of running wires down the mast. I found that there is approx. $1000.00 difference and I can't see it costing anything near that to have someone go up the mast and install a wind indicator and run the wires. This is my first boat so I have not installed any instuments before, however, I am pretty handy with tools but was going to pay to have someone do the mast work. Is it really that hard to install a hard wired wind indicator or is it really worth spending the extra money. Help!!
Thanks
Old 04-11-2007
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Moderator
Cruisingdad has a spectacular aura aboutCruisingdad has a spectacular aura about
Gulf,
Here is the ultimate boat question which will guide your life and answer many other boat questions:
WHICH DO YOU HAVE MORE OF... MONEY OR TIME?
And no, it is not a big deal but will you have to drop your stick?
- CD
Sailnet Moderator
Catalina 400 Technical Editor
Old 04-11-2007
christyleigh's Avatar
christyleigh christyleigh is offline
christyleigh is on a distinguished road
As CD says the classic answer to all questions is money or time but I'll try to add a little to his embedded question. Actually though.... you may not know if you have to drop the stick or not until after you have tried all other options. IF - you have little messenger lines hanging out of the bottom of your mast (as my mizzen does but main does not) doing it by ascending the mast for the vane attachment and a reasonably straightforward running of the wires is possible. Of course you may have messenger lines that are only seen - after lifting the mast and looking inside (most common) or none at all, meaning a more involved wire snaking job. If your boat is in the water it - may - be possible to have the mast raised with a crane or gin pole by the boatyard for the wire snaking without a full haul and block. Sorry... just re-read your original and since you may be doing through hull work for speed and depth you may need a haul and block any way. Just some comments to make your decision more complicated
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 04-11-2007
PBzeer's Avatar
PBzeer PBzeer is online now
Wandering Aimlessly
PBzeer has a spectacular aura aboutPBzeer has a spectacular aura about
The other upside to wireless is placement of the control heads is easier, as you don't have to worry about running wires from them as well.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
Old 04-11-2007
What are peoples thoughts on this new wireless technology? Has it been around long enough to be proven?
Old 04-11-2007
Moderator
Gulf,
I think it IS the future. How well does it work and interferencce, etc... I do not know. Do you have a Ham? Better check to make sure there is not a RF issue.
- CD
Sailnet Moderator
Old 04-11-2007
PBzeer's Avatar
Wandering Aimlessly
Most of the people I know who have it are racers.
John
Ontario 32 - Aria
JCP
Old 04-11-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Gulf-
The wireless gear is called TackTick Micronet, and it has been around and tested on the racing circuit long enough that several manufacturers and charter fleets have gone over to using it. While it is more expensive, it can be better for you in the long run, since it has much lower power requirements than the Raymarine gear does. The wind transponder and the displays are all solar powered, with self-contained solar cells.
Also, as TB has pointed out, it is far easier to install, since you don't have to run wires down the mast or through the cabin top for that matter. Also, PBzeer has pointed out, it makes adding additional displays, like a set of repeaters at the nav station, exceptionally easy.
I've used their gear on several boats but don't have it on mine. However, I do plan on switching to their gear when I get the time and a good excuse to do so.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 04-11-2007
labatt labatt is offline
I'd rather be sailing
labatt is on a distinguished road
One of the issues with the TackTick system is that there are some issues with older generation equipment working with newer generation. For example, when they came out with their new masthead wind stuff, it didn't work with the older stuff, so you had to replace the older stuff. From what I understand they gave very good trade-in prices though... it's new technology, but I think it's where the future will be. I love the solar aspect to it. I wish they could come out with a self-powered wireless transducer for depth and speed that you didn't need to do a wired through hull for!
s/v "Pelican" Passport 40 #076- Sort of For Sale - Willsboro Bay, Lake Champlain - http://www.passport40.org
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 04-11-2007
Labatt-
They do have an optional solar panel to power the hull transducer, but it has to be mounted on the cabin top and wired to the hull transducer.
Display Modes
vB code is On
AIC sailing into wireless world (The Republican) NewsReader News Feeds 0 01-20-2007 05:16 AM
UK & Netherlands. Tacktick to launch Wireless Maxi range for large ... - BYM News (press release) NewsReader News Feeds 0 11-02-2006 05:15 AM
Wireless electronics outfitting phowson Gear & Maintenance 0 09-14-2004 11:57 AM
Wireless instruments - esp. a windspped/angle transmitter WHOOSH Gear & Maintenance 6 01-18-2004 05:41 AM
Wireless Networking oz_hole General Discussion (sailing related) 1 10-06-2003 08:49 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
