Blogs
User Name
Old 04-11-2007
1970Columbia34's Avatar
1970Columbia34 1970Columbia34 is offline
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Garmin Transducer
We just got our new Garmin 545s and the in hull transducer. I have done some reading on this site and others and I am wondering how to mount the transducer. It came with epoxy, but have read about people unsing a pvc cap and epoxying that to the hull then filling that with mineral oil. What is the best way to do this I only want to do this once. I have a signet depth guage now so I plan to put the new transducer next to where the old signet one was. Any Help?
Scott
Old 04-11-2007
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seńor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
One of our prior boats didn't have a though-hull transducer and I installed an above hull unit, similarly to what you described. The transducer transmits/receives signals best through a liquid; mineral oil is commonly recommended, since it will not evaporate and is what I used.
If using an inverted PVC cap, select a slow-cure epoxy to avoid air bubbles, which could affect the sensitivity. Instead of a PVC cap, which will increase density of the hull, I cut a 4" high section off the end of a 4" dia PVC pipe (adjust to your transducer dimensions).
I then epoxied the pipe's bottom edge to the hull and filled with 3" of oil and secured a removable cap over the pipe - sealing the tube. A hole was drilled into this cap for the wire which I sealed with caulking. The 4" pipe height compensated for heeling angles. Worked without any problems.
True Blue . . .
sold the Nauticat
Old 04-11-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
TB's described the process pretty well. I would use a one of these instead, though and then cut the screw in fitting to mount the transducer onto it.
If you're new to the Sailnet Forums... please read this POST.
Old 04-11-2007
"I would use a one of these instead, though and then cut the screw in fitting to mount the transducer onto it."
you mean so I can screw the transducer out if needed, say if it broke or i needed to add more fluid?
Do I need to get the tranducer as close to the hull as possible? and this may sound stupid but where can you get mineral oil at, I have never been in the market for any...
Scott
Old 04-11-2007
Yup... makes maintenance a bit easier.
BTW, Mineral Oil is available at most pharmacies... it's used as a laxative... And you don't need the transducer as close to the hull as possible, as long as there is fluid covering it.
BTW, Johnson's Baby Oil is mineral oil plus fragrance... But I wouldn't use it, as the fragrance might affect the plastic... doubtful, but why risk it.
Old 04-11-2007
So here is what I have gathered, cut the bottom female part of the pvc at whatever angle gets the theads level, glue to the hull. Modify the cap so the transducer fits in it, fill with mineral oil, screw transduer and and your up and running. Thanks for all your help.
Scott
Old 04-11-2007
Yup...got it in one... and have fun. It's a pretty simple and fast project to do.
You should clean the PVC and then sand it lightly, so the epoxy will have a good surface to stick to. Don't forget to use a thickened epoxy and build up a good fillet to support the PVC pipe on the inside and outside of the piece. That will give the fitting strength enough so that if you step on it...it won't break free. Since this is going to be mounted on the bottom of the bilge, making it so that it can survive being stepped on is never a bad idea.
Old 04-11-2007
BarryL's Avatar
BarryL BarryL is offline
BarryL is on a distinguished road
why bother with mineral oil?
Hello,
Why not just epoxy the transducer right to the hull?
If you want to make sure the transducer will work, just put the transducer in a bag of water and place it where you want it. If it works in the bag of water it will work against the hull. Just use some epoxy and you are done.
I have HEARD of using a toilet bowl wax ring, and I plan on trying that later this month when I install my new chart plotter / sounder.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
lenoble@optonline.net
Old 04-11-2007
BarryL-
If you epoxy the transducer to the hull and have a problem with it...removing it is going to be an exercise in frustration. If it is mounted the way TB and I are recommending, it is far easier to remove or replace.
Old 04-11-2007
Valiente Valiente is offline
Valiente will become famous soon enoughValiente will become famous soon enough
True, but if you test it to a known depth, and it works accurately, a ring of silicon will do the trick. I have an Eagle fishfinder with a 200 KHz "puck" forward of the fin keel that agrees with both a measuring tape and my ancient Seamaster III cathode fathometer (aka "Plan B")
Display Modes
vB code is On
O'Day through-hull transducer mounting jknappsax O'Day 2 04-07-2007 12:13 PM
Garmin 498 C Sounder Opinions ? Transome mounted Transducer? chuck711 Gear & Maintenance 2 01-14-2007 09:11 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
