04-12-2007
Fstbttms-
I think it is more dependent on the hull design...than the other factors, aside from wind speed. A full-keeled design is obviously going to be affected far less than a fin-keeled racing boat design. In most full keeled designs, the prop is in an aperture between the keel and rudder. This reduces the drag that the prop is going to create quite a bit. In a fin-keeled boat, it is much more of a problem as the prop is usually further from the fin, and will create much more drag due to its far more exposed position.
However, I don't see any point in changing what was obviously a workable prop until he has used it and decided whether he can live with the limitations it imposes.
