-   -   Refurbishing portholes (http://www.sailnet.com/forums/gear-maintenance/31333-refurbishing-portholes.html)
smallyachts 04-12-2007 02:22 PM
Hello,
Well the time has come to cleanup and prepare the bronze portholes to go back into the new coachwork. I am having difficulty getting the glass out of the frame. I have removed the six screws that hold the piece in that holds the glass in place, but the bedding compound is not giving up very easily.
We did an initial cleaning with vinegar and salt, but would like to rebed all of the glass.
Any ideas, hints or suggestions for a non destructive means of removing the glass would be appreciated.
I can find no markings on the bronze castings, however they are elliptical in shape and approximately 14 in wide x 8 in high.
Also a source for the square rubber seals would be helpful.
sailingdog 04-12-2007 02:27 PM
smallyatchs-
It would help if you said where you were located as well as what kind of baot that you were working on.
You may need to use a razor to cut the bedding material away from the glass. Then remove the glass. After the glass is out, you can remove whatever bedding material is left.
You could contact a local glass company to find out about getting replacement seals. The bedding compound that they're using might be a butyl-rubber gasketing compound that is often used on car windshields.
