Blogs
User Name
Old 04-13-2007
Jotun's Avatar
Jotun Jotun is offline
Space cadet
Jotun is on a distinguished road
Solar charge controller
Can anyone recommend a simple solar charge controller for a small solar panel? The panel I have is for topping off the batteries while not in use. As it is, the panel just has two wires with alligator clips and nothing else. I'm guessing I need some sort of regulator to prevent overcharging, a fuse to prevent shorts, and a diode. The panel is not mounted but just sits in the cockpit. I have two batteries....
Old 04-13-2007
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Moderator
Cruisingdad has a spectacular aura aboutCruisingdad has a spectacular aura about
Jotun,
What is the output of the panels?
- CD
Sailnet Moderator
Catalina 400 Technical Editor
Old 04-13-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
The NC25A is a pretty good, inexpensive charge controller and will handle up to 25Amps.
While not an MPPT-type controller, its also nowhere near as expensive. About $150 USD.
If you're new to the Sailnet Forums... please read this POST.
Old 04-13-2007
Jotun's Avatar
Space cadet
CD,
It's on the boat. But it is small. The panel is the equivalent of a trickle charger. I'm guessing the PO just connected it directly to the house battery.
Old 04-13-2007
Moderator
SD,
Assuming it is just a trickle, do you even need a charge controller? My guess is no, but I have never direct wired.
- CD
Sailnet Moderator
Old 04-13-2007
Define trickle charger, and define what the on-board battery banks are made up of... that would help. IIRC, if the power rating of the panel is more than 1/60 the bank capacity, then a charge controller is recommended.
Since the OP hasn't stated the size of the panel or the battery bank, can't really say one way or the other. I prefer not to wire panels directly to the battery.. but would rather set them up on a fuse block and then put a output from the fuse block on a switch...
Old 04-13-2007
Jotun's Avatar
Space cadet
I have two 12v wet-cell batteries on board. But, sitting here at work, I can't tell you the size of the panel. It looks, however, something like those little 1.8 watt panels. I'll bring it home this weekend.
Old 04-13-2007
If that's the case, and the batteries are even Group 24s, I doubt it's even keeping them topped off. And definitely no charge controller needed.
Old 04-13-2007
camaraderie's Avatar
camaraderie camaraderie is online now
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
25 watts is less than two amps...no charge controller needed. It cannot really charge your batteries...just keep them topped up when you are off the boat.
Old 04-13-2007
kennya's Avatar
kennya kennya is offline
kennya is on a distinguished road
if your charger is 400 miliamps or less you do not need a controler.
Display Modes
vB code is On
Best Solar Charge Controller? mmccoy Gear & Maintenance 1 07-28-2004 11:46 PM
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 07:00 PM
The Right Size Solar Panel Don Casey Miscellaneous 0 01-18-2000 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
