Help with Ericson23 replacement parts... - SailNet Community
Blogs
Old 04-14-2007
rbaroni is on a distinguished road
I've purchased an Ericson 23, and I am getting started getting it ready to go. At this point, I have three items I'd appreciate any suggestions on, all of which I have included pictures. 1. At the base of the mast where the steel pin slides through a sleeve that holds the mast to the mast base support is a metal sleeve liner that appears to be brass or something similar. It needs replacing. What exactly is it, and where might I find a substitute? 2. The aluminum cap on the bow where the rub rails terminate has been damaged needs to be repaired. Any ideas on where to get a suitable replacement? 3. The bottom bracket that holds the rudder to the boat has small cracks radiating from it, and it is slightly loose. Should I fill the holes with epoxy and redrill? I couldn't get any of the pictures to upload. They weren't too big of files, and were in the proper format. Thanks in advance, I sincerely appreciate the help and suggestions.
Old 04-14-2007
pluscard is on a distinguished road
I couldn't get a pic to upload earlier this week - but it was my first time.
Good luck with the erickson.
Old 04-15-2007
Rbaroni-
Post the photos to a flickr.com account and then post the images by linking to the flickr.com image url via the image link icon, which looks like a mountian landscape with yellow sky in the quick post box. see image below—it has the blue border.
OMC Saildrive Parts ARE Available kennethgelao Gear & Maintenance 9 05-04-2010 04:00 PM
Volvo Penta Marine Diesel MD11C Parts Source? ntheyer General Discussion (sailing related) 35 04-07-2010 03:33 PM
chroming parts CharlieHustle Gear & Maintenance 1 12-21-2006 04:46 PM
Catalina 30 Parts capttack Gear & Maintenance 2 07-19-2004 06:33 AM
Spar replacement parts BenDaniels Gear & Maintenance 1 04-02-2001 10:07 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
