Old 04-17-2007
S/V Perwinkle
lmitchell is on a distinguished road
Another spring project... Help Please.
OK... I get it. The projects never really end.
In light of that I've pulled down the poorly fitted bimini and dodger. And will be taking off the mounting hardware. How should I fill all the little screw holes left behind. Should I drill them out and fill with epoxy? Or what?
Thanks,
Lawson
Old 04-17-2007
deckhanddave's Avatar
deckhanddave is on a distinguished road
the short answer is yes. The long one involves the process of checking for water damage, removing it if there is any, reaming the holes, and filling them (with thickened epoxy). I'd run down to a book store and take a look at casey's boat books to see how he does it.
Old 04-17-2007
I'd check to make sure whether the core is dry there. If it is, then just drill and fill with thickened epoxy. If not, then you've got some work ahead of you. Either Nigel Calder or Don Casey's books will be a good resource for this.
Old 04-17-2007
tenuki's Avatar
Helms ALee!
tenuki will become famous soon enough
Get the big casey book that is a compilation of the 5 or 6 core books he has published. the big book is a better printing and uses blue for parts of the illustrations, making it much easier to read than some of the other printings.
Old 04-17-2007
Tenuki-
That would be Don Casey's Complete Illustrated Sailboat Maintenance Manual.
TODAY: United Divers Spring Sale 2006 (Spring Is Here and it's time NewsReader Mass Bay Sailors 0 05-20-2006 11:15 AM
The Spring Launch Bruce Caldwell Gear and Maintenance Articles 0 04-30-2002 08:00 PM
The Spring Launch Bruce Caldwell Cruising Articles 0 04-30-2002 08:00 PM
Spring Lines Mark Matthews Seamanship Articles 0 08-06-2000 08:00 PM
