One of the better ways to mount a float switch is to mount it to a long, skinny vertical board or piece of PVC pipe. Then you can use screws or other methods to mount the board or pipe in a location that positions the float switch where it needs to be. The bilge
pump should be mounted to the same board/pipe. That way, if you need to service it, you can just pull it up and work on it.
POST.
