Blogs
User Name
Old 01-27-2002
RobHoman RobHoman is offline
RobHoman is on a distinguished road
If you were going to install mast steps...
How would you attach them to the mast. Would you drill and tap to use machine screws, or would you use stainless steel rivets?
Please limit responses to this question to those who have done it.
Thanks............
Old 01-27-2002
SailorMitch's Avatar
SailorMitch SailorMitch is offline
Senior Moment
SailorMitch will become famous soon enough
Last time I had my mast down, I installed 2 of the folding steps near the top of my mast so that if I ever had to work there, I could stand on them if needed. I placed them so that the top of the mast would hit me about chest height. I drilled and tapped the holes and installed them with SS screws. I used anti-seize to prevent any corrosion between the SS and the aluminum mast.
Old 01-28-2002
goduke goduke is offline
goduke is on a distinguished road
Screws should work fine if there''s enough thickness to provide a good bite - that''s the big question. I''d ask the manufacturer of your mast but I wouldn''t be surprised if they recommended rivets. Load bearing hardware on masts (goosenecks, pad eyes, etc.) that is not reinforced or through bolted is very often riveted.
Display Modes
vB code is On
Deck stepped Mast-Always Bad ? Mrs Mutiny Buying a Boat 23 02-01-2008 10:05 AM
which 38ft boat? bluewaterdreamer Buying a Boat 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Buying a Boat 3 09-09-2006 05:33 PM
what mast? jrwright Buying a Boat 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
