Old 04-20-2007
LWinters is on a distinguished road
Send a message via MSN to LWinters
Primary Winches: Barient vs Lewmar
I need some help. I've read a few places that the Lewmar 40ST was a direct replacement for the Barient 26. I ordered up a pair from Defender and they sure do look smaller. The internal stem is very similar, but the drum housing is noticably smaller.
I've always understood that you wanted to error on the side of an oversized primary winch and I don't want to mount these guys if I've underdone it. The boat is a 39 foot Ketch. Any ideas?
s/v Jargo
Singlehanding to Panama and beyond
Old 04-20-2007
The Lewmar 40ST has a mechanical leverage of 40:1, the Barient 26 I believe had one of 26:1. The real issue with most modern winches is their gearing ratio. The 40ST has a gearing ratio that will provide you with more leverage. How big is the genoa you are going to be using these winches for?
I have 40ST's on my boat and use them with a 274 sq. ft. genoa...and they're about right for that size sail. If the sail were much larger, I would think that the 48ST might be a better choice.
Old 04-20-2007
The primaries will handle both the 150% genoa and the cruising spinnaker. Thanks for the clarification Sailingdog. Sounds like I had it right even if I didn't know exactly why.
s/v Jargo
Old 04-20-2007
Glad to help...
BTW, the spinnaker, even though it will have much more surface area, doesn't need a correspondingly larger winch because the winds you use it in are generally weaker than those you use the genoa in.
Old 04-20-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
The spinnaker is also by far a much lighter sail, weight wise.
S/V Scheherazade
Old 04-20-2007
Location: Ft. Lauderdale, FL currently CLODs [cruisers living on dirt]
svsirius is on a distinguished road
Barient did not size there winches according to the current convention.
If the winch loooks smaller it probably is.. you might be better served buy exchanging them for a set of 44s. Also go to the Harken web site and look up compuspec they will help you size winches or anything else for your boat.
Jon D
SV Sirius
Moody 47
Old 04-20-2007
The 40 are enough for what you want
Old 04-22-2007
ericroline's Avatar
Santana 525 PRESTO
ericroline is on a distinguished road
Winch Sizes
The Cal 9.2 came with Barient 25 primary winches which are 40:1 power.
The C&C 35 came with Barient 26 primary winches which are about 44:1 power.
Barient 27-48 are 48:1
Winches - Lewmar Vs. Andersen BELLATRIX1965 Gear & Maintenance 11 02-19-2007 10:32 AM
Lewmar WInches ross99 Gear & Maintenance 1 03-06-2004 03:17 AM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
