Old 04-20-2007
STARWINDY's Avatar
Jersey Member
STARWINDY is on a distinguished road
Help Stop The Squeak!
Hello, I am in the midst of completing a full refit of my Starwind22 and I need some sanity saving advice. The Starwind22 has a "pop-top" feature much like a VW campervan. The unit that pops up has two peices that slide in on themselves to allow even more headroom. The issue is with the teak rails that the plastic slides along. When you slide open the top it makes the most horrendous chalkboard scratching sound that can be heard in the next marina.
Is there something I can lube inside the rails without harming the teak?
Old 04-20-2007
McLube Sailcote... Stuff works wonders...
Old 04-20-2007
johnr
jr438234606 is on a distinguished road
Sailcote is great. If that doesn't work, try rubbing candle wax on it.
Old 04-20-2007
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
bee's wax and linseed oil combo won't harm the teak wood work... This is an old fashion furnisher polish.
Old 04-20-2007
Brezzin's Avatar
Brezzin is on a distinguished road
Send a message via AIM to Brezzin
I had a starwind 223 back around 1986 Really liked the boat. Had a nice bit of sail area and easy to handle. If memory serarves me the companionway top slides into a trunk which is hinged and then can be pushed up. The companionway top slides on two teak rails.
I think sailcote is a good suggestion. But is the noise comming from the teak or inside the trunk?
Old 04-20-2007
Linseed oil is far more likely to collect dirt than McLube SailCoat is. Sailcoat is also, by far, the simplest to apply...aim and spray...
Old 04-20-2007
STARWINDY's Avatar
Jersey Member
Yes...you are exactly right about the Starwind setup. As to the actual cause of the noise...it is certainly the plastic/teak rubbing. I have the assembly off the boat and makes no noise when companionway slides into the trunk. I have McLube and will give it a shot. Thanks for the tips.
Old 04-20-2007
kennya's Avatar
kennya is on a distinguished road
sailcote is a good suggestion I had a 82 Starwind 22, loved the boat all except the cable singing on the swing keel.
Friends stop search for missing sailor - Leading The Charge NewsReader News Feeds 0 02-19-2007 11:15 PM
Friends stop search for missing sailor - Jordan Falls News NewsReader News Feeds 0 02-17-2007 01:15 PM
Diesel won''t stop stephens84 Gear & Maintenance 2 05-22-2004 04:53 AM
How to Slow Down and Stop John Rousmaniere Learning to Sail Articles 0 08-03-2003 08:00 PM
How to Slow Down and Stop John Rousmaniere Seamanship Articles 0 08-03-2003 08:00 PM
