Standing rigging replacment - Page 3 - SailNet Community
post #21 of 44 Old 04-24-2007
Wish I never found SN!
SimonV's Avatar
Originally Posted by KeelHaulin
Newport41-
My boat (a '79 Mk-I) was re-rigged ~3 years ago before I purchased the boat. The re-rig included new terminals/turbuckles (swaged); with running backstays, Harken Mk-III Unit 2.5 furler, and insulated backstay, new running rigging on the mast (7 halyards), new stainless lifelines, spartite mast partners. IIRC the bill for the rigging (no yard labor/time included) came to appx. $18,000.
A similar boat (C&C Landfall 38) has a re-rig price breakdown listed here:
Rigging Cost
That still makes it $3800 for standing rigging replacement + labour.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is online now
post #22 of 44 Old 04-24-2007
STARBOARD!!
KeelHaulin's Avatar
The work done on my boat and the C&C 38 included more than just standing rigging; but it is typical of the overall job that would be done during a mast refit. While the rigging alone may cost ~4,000 by the time you add running rigging, furler (if you add/replace), mast repairs, etc the final cost of a spar refit could easily be 15-20k. It's not 4k in parts and 14k in labor; I'm glad the refit was done just prior to purchase on my boat.
KeelHaulin is offline
post #23 of 44 Old 04-24-2007 Thread Starter
Cam,
Why are we getting rid of our roller furling?
Cost. I would prefer to have one but I would rather spend the money on things we need. It's on the "want list" not the "need list" in other words.
I can also see the pros of not having one, especially in our situation. First, we are a large and young crew. I realize that doesn't make going forward in a large sea safe but I think it lowers the risks. Second, Our sails are not designed to sail "reefed" on a furler, they just don't sit right when partly furled and adding foam or recutting or both is again, getting expensive. So, if the wind picks up we have to go forward anyway. Third, ever had a furler get stuck with one wrap on so you can't drop the sail and you can't furl it furter either?....Me niether but if a squal was coming I would have to say that for lack of a better word, that would suck. I know it's not a huge worry but I thought I'd mention it. So to recap it's really cost, and the incompatibility of our sails.
As for the backstay insulators. Well, from the reading I've done it sounds as if good quality insulators are no longer a weak point although they have a shorter life span. I'm open to suggestions for alternatives.
p.s. I'm always open to critics. That's why I post. If it seems weird to you than maybe I'm missing something.
Newport41 is offline
post #24 of 44 Old 04-24-2007
Originally Posted by Newport41
Cam,
Cost.
You don't mention what brand of furler you have, or else I missed it.
It doesn't matter what type of insulator you use, it will in fact be weaker than the wire and swages. The reason for this as far as I understand is that the studs are threaded into plastic. The good thing about the Hayn Hi-Mod insulators is that they are failsafe. Meaning that even if they fail, ie the plastic gives way they will only loosen and not come apart completely. They will not be insulated at that point but you will still have a backstay.
knothead is offline
post #25 of 44 Old 04-24-2007 Thread Starter
Keelhaulin,
Thanks for the link, very helpful. Like I said before, I'm only looking at what I should be planning on for the fall, not an exact cost, so that was perfect.
post #26 of 44 Old 04-24-2007 Thread Starter
If anyone has suggestions for alternitives to an insulated backstay for the SSB I'm very interested.
Knothead,
the brand of furler won't come to me right now and my paperwork is all down at the boat. I can tell you however that is is 20+ years old and was a novelty at the time because it was sectional and thus easily shipped. It also has no integral wire stay, so if the sectional foil, or a bearing, fails it's game over. I have considered running a wire stay outside the furler but I haven't solved the logistics of it as of yet. Thanks for the advice on the failsafe insulators, I'll look into those further. It seems like a sensible design
post #27 of 44 Old 04-24-2007
[quote=Newport41]If anyone has suggestions for alternitives to an insulated backstay for the SSB I'm very interested.
I think it's been mentioned before on this thread but you might want to consider just having an appropriate length of wire which you can haul aloft with a spare halyard.
From what I understand that works as well as having a insulated backstay except for the fact that you have to deploy it when you need it. I guess it depends on how much time and how often you will be using the radio.
The cost of insulators are at least $200.00 to $300.00 each. You could pick up a used piece of 1x19 from your local rigger for nothing. You might even find that they have an old insulated backstay from a smaller boat that they will give you. (in case you have wire halyards)
knothead is offline
post #28 of 44 Old 04-24-2007
moderate?
camaraderie's Avatar
Newport...in your original post you said you were getting rid of your furler. To me that implied you had a working furler and at least one sail that worked on it. You further implied you were getting rid of it for safety reasons "i.e. lack of confidence". Then you said you were going to add backstay insulators which add 4 more points of failure to an existing backstay. That is what was wierd to me.
Nothing wrong with a choice to use an existing forestay and existing hank on sails...I just didn't understand why you would delete a good furler for safety and then "weaken" the safety of a backstay at the same time. Understand now. I will agree that with good insulators the chances of a backstay parting there is small...but nevertheless higher than without insulators.
Bill Trayfors posted info here on alternatives to backstay antennas that made a lot of sense to me. You might want to PM him check out his post on this thread:
SSB antenna
camaraderie is offline
post #29 of 44 Old 04-24-2007
Helms ALee!
tenuki's Avatar
18000?!?!?! Yikes! This reminds me of the joys of owning a 24 footer!!! ;P
tenuki is offline
post #30 of 44 Old 04-25-2007 Thread Starter
Yeah tenuki, tell me about it.
Cam,
It is a working furler but having little confidence in it and no forestay, I don't want to take it offshore. Our sails work great on it for cruising aroung here but as I said they don't reef well. As I said above, I'm considering running a wire forestay and keeping the furler for convenience (double track, weekend cruising). We'll have to see about the logistics of that. As for the insulated backstay. I'm very glad you brought that to my attention. I agree that the less links in the chain the less potential problems. I'd like to avoid it if at all possible, especially as we have only the single backstay. Thanks for the link I will explore other options.
Standing Rigging Too Old? StillInShock Gear & Maintenance 79 11-23-2011 01:18 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 09:00 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 08:00 PM
Standing Rigging Storage Jerry Hammill Gear and Maintenance Articles 0 10-15-2001 09:00 PM
Replacing Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-22-2000 08:00 PM
