04-21-2007
moderate?
You do need a regulator just to be safe despite the low amperage as the voltage can go as high as 16.5V which is too high. The little Sunguard4 on the same linked page will suffice. You can put a float charge on both batteries as you will get about 1.4 amps in direct sunlight so you can keep your batteries from discharging while you are away. As you'll only average about 7 amp hours on a sunny day...the panel is not useful for much more than that except for maybe a very ocaasional bige pump cycle. Just connect the controller to either batteries positive and negative terminals. The batteries will equalize their charge to be at the same level.
