04-22-2007
Sand it mostly fair, but leave enough rough spots for the new glass to "grip" to.
Use fibreglass tape here. The Kevlar idea is good.
When your glassing is done (and I think you might want to put a Kevlar strip down the centerline and then fibreglass tape strips "lapped" to either side), consider applying a two part epoxy barrier coat or two over the entire job. Then anti-foul over the whole thing.
I have found that it pays to double up the anti-foul coats on the 'leading edges" of the keel, rudder and bow.
Good luck...It's a messy, tedious job, but the results are gratifying.
If you can take off the rudder and get the work area flat on a bench with vises, the job is a lot easier and quicker, because under a boat is typically a cool spot whereas doing this in a garage means you can use lights to warm the epoxy so it kicks faster. Also, a LOT fewer drips and "tape slide" if you've got the consistency a little off.
