Old 04-22-2007
GregGreason is on a distinguished road
Rot in Bulkhead C&C Invader 36 (Frigate)
I recently discovered rot in the main bulkhead where the upper shroud chainplate attaches. This is a fairly substantial bulkhead - about 1" thick. The roted area is roughly 2 inches wide by 12" high at the upper hull edge of the bulkhead.
Do anyone think that I can fill the area with thickened epoxy or should I be attemting to replace the area with a shaped piece of plywood? Replacing the total bulkhead would be a major piece of work as so much of the interior joinery is attached to this bulkhead.
Greg
Old 04-22-2007
Here .. Pull this
Sailormann will become famous soon enough
It seems like (and is) a big job right now, but this is probably one of the most important junctures of your boat. The bulkhead is that thick because it is responsible for transmitting the stress of the rig and distributing it to other parts of the boat.
I think that filling it with epoxy is a really dangerous idea. In the end, you are liable to end up with an even weaker boat. The bond formed between old, deteriorated wood and the epoxy will not be strong enough to deal with the load.
You might be able to cut away the rotted part, replace it with new, well-sealed wood, and then sandwich that between two EQUALLY STRONG pieces of wood that are through-bolted (lots of bolts here - not one or two) holding all three pieces together. Make sure that the pieces on either side are much larger than the one in the middle, and make sure there a lot of bolts on the perimeter, as it is these bolts that are taking and distributing the load - not the sandwiched piece in the middle.
Good luck and let us know what happens...
The sooner you deal with it - the better.
Old 04-22-2007
That's what I having been leaning to - replace a section of the bulkhead. The adhesion of just epoxy would be an issue that would haunt me for all future sailing days.
Thanks for your input.
Old 04-22-2007
Of course, the best solution would be to remove the bulkhead and replace it completely.
However, whatever method you use to fix the problem area... don't forget to seal the plywood with epoxy and then to pot the holes for the chainplate fasteners, much like you would with a cored deck. That way, any leaks at the chainplate will result in a wet interior, but won't cause any future deterioration of the bulkhead.
JEFF H input wanted mikehoyt Boat Review and Purchase Forum 21 01-30-2010 07:12 PM
replacing bulkhead sneuman Gear & Maintenance 8 11-13-2003 03:29 AM
replacing bulkhead sneuman Gear & Maintenance 3 06-03-2003 03:24 AM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 04:07 PM
