04-24-2007
Sunrise-
Is the problem on the raw water side, or the fresh water, closed loop anti-freeze laden side? Have you tried flushing the heat exchanger? If so, does water pass freely through it?? Does the water pump work?? If it is powered by a pulley and belt off the diesel, have you checked to see that both the pulley and belt are tight?
