Blogs
User Name
  #11 (permalink)
Old 04-24-2007
cardiacpaul's Avatar
cardiacpaul cardiacpaul is offline
MarineSurveyor
cardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura about
2k is STILL cheap. regardless of whatever else they are doing.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
  #12 (permalink)
Old 04-24-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
What boat is this? And, is there any sign of damage or deformation aft of the keel, or arond the keel bolts?
If you hull was built (as some are) in halves that are joined afterwards, this could be the centerline joint opening up as the boat flexed over the keel, or just a cosmetic top layer moving. So some "optimistic caution" is called for.
  #13 (permalink)
Old 04-24-2007
Idiens's Avatar
Idiens Idiens is offline
Larus Marinus
Idiens is on a distinguished road
We needs pictures!
I think from your description the yard might be right about hull flexing. Where is the mast foot support in relation to the crack - just behind it?
  #14 (permalink)
Old 04-24-2007
brak brak is offline
Sea Slacker
brak is on a distinguished road
Just removing the gelcoat over the crack is an easy job. I had this done on one of my previous boats over the entire keel-hull joint. Hired a guy that does "bottom peeling" and he used the peeler machine (basically an electric plane), took him less than an hour for the entire seam and i paid accordingly. So, I think uncovering a 6" crack should be pretty cheap.
Ditto for covering it up if there is no problem - some epoxy with silica filler and a few hours of your time is all that is needed.
By doing this, you will be able to find out what the problem really is. Without that you are just speculating. In my experience what looks "bad" from the outside could easily turn inconsequential and, conversely, something that looks small and insignificant could be a sign of a serious problem.
  #15 (permalink)
Old 04-24-2007
jr438234606 jr438234606 is offline
johnr
jr438234606 is on a distinguished road
This is a 1981 Bob Perry Cheoy Lee. The mast is keel-stepped. The crack is not actually in the keel. It is in the hull just forward of the keel, directly in the center. (Again, pictures to follow in bit! ) I don't see any keel bolts. How do they attach a keel like this? Is it just one continuous piece, formed seamlessly with the hull? Or, do they still use bolts and the bolts are just glassed over? Sorry, my ignorance is showing.
  #16 (permalink)
Old 04-24-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Not if this isn't fixing the underlying problem that caused the crack.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
  #17 (permalink)
Old 04-24-2007
johnr
We're thinking that my grounding the boat caused the crack. In that case, no amount of money would be enough to fix the problem.
  #18 (permalink)
Old 04-24-2007
Yes, but did the grounding cause some of the hull-keel bolts to fail? Did it cause the hull to flex and break stringers? That's the question. If either of those happened, you can fix the crack, but then the motion of the boat will cause the hull to crack again, since the underlying structure of the hull is damaged. You need to know if that is the case or not.
  #19 (permalink)
Old 04-24-2007
MarineSurveyor
pictures... and get a pro to gander at it.
  #20 (permalink)
Old 04-24-2007
Sure, you could always buy something that grounding doesn't bother, like one of these:
Display Modes
vB code is On
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
