Old 04-24-2007
dvpamenter is on a distinguished road
Acrylic window sealer
Putting new windows in Ossifrage. The windows are acrylic, will be slightly inset and held lightly with mechanical fasteners. What sealant/adhesive product have others had +++ success with?
Clear Sailing
Alado agent - Canada
Old 04-24-2007
I would use Boatlife LifeSeal or 3M 4200, which are both polyureathane-based sealants. However, be aware that neither BoatLife LifeSeal or 3M 4200 stick well to teak. Other ways to do it are to use neoprene gaskets or butyl rubber-based window sealant tapes.
I would avoid polysulfide-based sealants, like BoatLife LifeCalk, as they tend to be a bit more reactive and while good for bedding hardware, will tend to attack plastics, like ABS, Lexan and Acrylic/Plexiglass.
Old 04-24-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
You may also want to look into butal sealent the kind that is used for auto windshields.
S/V Scheherazade
Old 04-24-2007
Are butyl sealants at all adhesive or need I rely on the mechanical (through bolt) fasteners?
Clear Sailing
Old 04-24-2007
ntheyer is on a distinguished road
Boatlife works well with teak if you use their primer specifically for teak. The primer is expensive ($16.00 or more for a half pint or so) but works very well.
Old 04-24-2007
Depends on the exact sealant you're using, but most of the butyl tape sealants are fairly sticky IIRC.
Old 04-24-2007
Neises's Avatar
Swabbie
Neises is on a distinguished road
I've been leak free (rain, hose, & lake, no salt) for a couple months with good ole GE Silicone II. $4 per tube from HomeDespot. Plexiglass to vinyl frames and fiberglass hull.
Just throwing it out there, not saying it's proper. My boat is a dingy with windows.
Pete
Expo Solar Sailer
Old 04-24-2007
Valiente's Avatar
I use the same thing, but in combination with a new version of the original C&C/CS gasketing. Silicone (clear) worked all last year with nary a drop and we took some green water amidships (not a lot, but enough to show any caulking shortcomings!)
Window gasket sealant.. groundhog Gear & Maintenance 38 05-11-2007 12:07 AM
S2 11.0A Lexan Window Replacement longwaterline Gear & Maintenance 1 02-20-2007 12:43 PM
Need Advice: window leaks NewsReader Mass Bay Sailors 0 01-16-2007 06:15 PM
Sealer for non-marine plywood PBzeer Gear & Maintenance 7 01-03-2007 12:06 PM
jib view window ddilman Gear & Maintenance 2 07-25-2005 10:02 AM
