Blogs
User Name
Old 04-25-2007
Bluewater4us Bluewater4us is offline
Bluewater4us is on a distinguished road
Need Help with Fuel for stove!!
In my new to me sailboat I have a Regal Stove/ Oven. I went to light it and found out the tanks were empty. I pulled out the tanks on the boat to get them filled. I went to a place because they seemed different. They are slightly bigger than scuba tanks and have a european fitting on them. That is what the guy at the gas place said. He also said the tanks are marked methane. This doesn't make sense to me. Could this be right? If so can I change it over to propane without harming the Stove/ Oven and not much cost?
Thanks for any help or guidance
Old 04-25-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
BW4-
What you've got is probably a CNG stove. CNG is comprised mostly of methane. If you convert the system over to propane, you will have to change the burners on the stove and oven, as well as the fittings at the tank end.
IIRC, ABYC requires that gas lines have fittings that are permanent—not using hose clamps.
If you're new to the Sailnet Forums... please read this POST.
Old 04-25-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Did you buy the boat in Europe?
I'd check with a CNG filling station to see if those fittings will work with a US CNG refill, and if they do, see if the gas burns acceptably well. Or, they may be able to change the fittings. This is not just a matter of screwing in fittings, they are limited by law regarding tank marking, pressure ratings, and fittings so conversions may be problematic.
There are a lot of PITA rules about gas tanks and fittings, but they are there because folks cleverly manage to blow themselves up every year, I can't argue in favor of common sense when the "booms" are so big.
In most of the US CNG is relatively hard to find, even though it is safer than propane (it floats out of the boat instead of pooling in the bilge) so consider that as you look at your options. A stove will usually work with the "wrong" burners and jets--it just won't work well. It is worthwhile making your system all "correct".
Display Modes
vB code is On
Below Deck Plastic Fuel Tank Grounding Question Panacea1 General Discussion (sailing related) 3 06-29-2006 07:15 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
