Old 04-25-2007
Bluewater4us is on a distinguished road
CNG to Propane
I am looking to change my CNG set up to Propane. Is it expensive? How do I do it? Will I need to get a new Stove/Oven? I have a regal ( I think) Stove/oven. I am having troubles getting the tanks filled and also the tanks have european fittings.
Any help is welcome
Old 04-25-2007
It depends... Some stoves will have propane burners available, so that you don't have to change the entire stove out.
I'm not sure about whether the regulator will work with propane or not, but believe it and the hose leading to the tank will have to be changed out for new propane ones. You'll also need a new tank more likely than not.
Old 04-25-2007
Sailmanles
longwaterline is on a distinguished road
Why would you want to switch to propane? CNG which I have on Wave Dancer, an S2 11.0A, is a superior fuel and is much safer than propane. Admittedly it is more difficult to refill but you can find sources or have the cylinders delivered. Why propane became the standard is not clear. Probably the propane lobby.
Old 04-25-2007
donrr1's Avatar
donrr1 is on a distinguished road
In some stoves the conversion is as simple as changing one orifice. It's simple if YOUR stove has a changeable orifice. See the literature that came with the stove to find out. If that is unavailable, contact the manufacturer. There may also need to be a change made to the 'air gap' in all of the burners. I'm not sure if it needs to be longer or shorter. Check with the manufacturer to see if the pressure setting on the regulator is acceptable for your application.
Don
I love being on an Even Keel WTF are YOU lookin at?????
Old 04-25-2007
I found a place that can fill the tanks but they can't because of the european fitting on the tanks. Is there a solution to that? If so where can I get the parts?
Old 04-25-2007
IIRC, Propane became the standard because it was easier to ship over long distances for many years, compared to CNG. Propane also provides far more heat per unit volume than does CNG.
Propane — 425.31 kJ/kg 1.91 kg/m3
Methane — 510 kJ/kg 0.68 kg/m3
Old 04-26-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
For info on this and your other CNG thread:
Corp Brothers Corp Brothers-Marine Products has a listing of tank exchange / filling locations by state.
They also carry parts Corp Brothers Marine Products that may allow you to fill / swap tanks instead of converting the stove.
Old 04-26-2007
Bill Mc's Avatar
Coastal Cruiser
Bill Mc is on a distinguished road
Why LPG ???
Mmmm Lets see...
CNG tank exchange $80.00 + shipping
Our last bottle lasted about 4 weekends. Breakfast, Lunch and Dinner for 2 people and some guests plus baking biscuits for B-fast. About 20hr cook time.
LPG tank $10.00 can purchase anywhere. Just installed details to come.
Fiberglass LPG tank for safety, no BLEVE, no rust , Rail mounted with a sunbrella cover to protect tank from UV. The tank was $100, the hose and fittings $50 and the conversion kit for the seward range $140 so about $300 total. I'll post some pictures when I get back from the boat. At 285# I can put away some groceries. and boy can my Baby cook
PS I have a CNG Tank and Regulator for sale for $300
Fair Winds,
Bill
Old 04-26-2007
Bill-
How do you like the composite tank? Is it the clear one, where you can actually see the propane levels through the tank wall??
Old 04-26-2007
Bill .......... Where did you get the parts to convert? Where did you get the conversion kit for your stove? Should I contact the Stove manufacturer? I saw the tanks in West Marine Catalolague. I think I can make them fit no problem. I just don't want to buy a new Stove/oven.
Paul
Propane to CNG MDDesperado Gear & Maintenance 5 01-18-2008 04:41 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
Converting CNG to LPG Tom Wood Cruising Articles 0 12-25-2001 07:00 PM
CNG to Propane Conversion RichardToba General Discussion (sailing related) 15 07-18-2001 10:46 AM
cng to propane conversion carisea General Discussion (sailing related) 0 07-18-2001 10:41 AM
