Knot usage for sheets and halyards - Page 2 - SailNet Community
post #11 of 56 Old 04-25-2007
HS—
To clarify—I use pin-retaining shackles on mainsail halyard and topping lift, but use snap shackles on the spinnaker and genoa halyards. These are attached to the halyard via a buntline hitch.
I do not use shackles on the clew of any headsail, since that means instead of getting a bruise for your trouble, when trying to tame a flogging sail, you get a concussion or worse. I use bowlines for the genoa and spinnaker sheets, but will probably go to a lark's head and a single longer sheet at some point in the future.
One thing on the bowlines—leave the tails a bit on the long side and tie the loops as small as possible. This makes it much less likely that the bowlines will shake out, which can happen on stiffer, older lines.
One neat trick I've seen for genoa sheets is an eyesplice with a stiffened tail that is used to lock the eyesplice into the clew of the sail. I wouldn't recommend this for a larger boat though.
sailingdog is offline
post #12 of 56 Old 04-25-2007
poopdeckpappy's Avatar
Man I wish I had a picture of the lark head knot, it's slick, I use it now on all 3 sails, a 150, 135 and a 90, the sail blows right threw and has never hung up on me, where the bowline did
poopdeckpappy is online now
post #13 of 56 Old 04-25-2007
Sea Slacker
I think this may be it: How to Make a Lark's Head Knot | eHow.com
brak is offline
post #14 of 56 Old 04-25-2007 Thread Starter
Zanshin's Avatar
Sailingdog - ahh, that makes more sense. Since I've alread got 2 lines of appropriate length I'll have to use those. I checked up on the internet and it seems the cow hitch (or Lark's head or several other names) isn't quite what I was looking for.
HelloSailor - electrical tape to get the standing end out of the way. lol - not to carry any load. I have in-mast furling but you are correct, the genoa and mail halyards are spliced and shackled - I was looking at the topping lift which has a bowline.
Zanshin is offline
post #15 of 56 Old 04-25-2007
Originally Posted by brak
Yes Sir, that be it
post #16 of 56 Old 04-26-2007
ok wait, you use a larks head straight through the clew of your jenny? Mine is hank-on, so I am not sure I could do that, although I like the idea of not having to worry about it hanging up.
skrap1r0n is offline
post #17 of 56 Old 04-26-2007
Skrap-
Why would being a hank-on sail affect whether you could use a lark's head knot for the jib sheets??? Granted, untying a lark's head from the clew of a jib, as you're trying to switch headsails is a royal PITA... but it would still be doable.
post #18 of 56 Old 04-26-2007
Skrap, mines hanked,
Also, I don't understanding why you would want or need to untie the sheets when you do a sail change, you wouldn't with anyother sail change/knot configuration
post #19 of 56 Old 04-26-2007
my sheets clip to the clew of the jib. when I get done sailing, I pull off my sheets and roll them up and stow them below, then I remove the jib.
the clip makes it easy to do this.
post #20 of 56 Old 04-26-2007
Some people don't have a dedicated set of sheets for every sail... So untying a lark's head knot, when doing a sail change, with 50-100' of wet jib sheet to pull through is going to be less than fun.
Internal Halyards DWH Gear & Maintenance 9 07-14-2008 06:19 PM
Knot usage for sheets and halyards Zanshin Gear & Maintenance 8 04-25-2007 09:35 PM
Running Internal Halyards Dan Dickison Gear and Maintenance Articles 0 03-25-2002 07:00 PM
Wire-Rope Halyards Tom Wood Gear and Maintenance Articles 0 08-14-2001 08:00 PM
Samson Pre-spliced Halyards Dan Dickison Gear and Maintenance Articles 0 12-28-2000 07:00 PM
