Knot usage for sheets and halyards - Page 5 - SailNet Community
post #41 of 56 Old 04-26-2007
midlife, Thats all there is to it. I thought I invented it until this thread. its so easy it seems evil.
capt.stu is offline
post #42 of 56 Old 04-26-2007 Thread Starter
Zanshin's Avatar
Originally Posted by poopdeckpappy
...call a " Gathering wrap "...
I think the term for this whipping is a common whipping.
Zanshin is offline
post #43 of 56 Old 04-26-2007
Pappy-
That picture is correct for a Lark's head knot, but INcorrect for a Prussik. The cord makes two loops around the pole in a Prussik, adding the extra friction bite that allows it to be used to climb poles--or other lines.
A Prussik is considered good under load only, it will not hold when slack, so I'd be reluctant to use it or a lark's head for any foresail. Holding up a fender on the lifeline, for short term, sure. (With an added hitch to keep it longer.)
hellosailor is offline
post #44 of 56 Old 04-26-2007 Thread Starter
Zanshin's Avatar
I've been using today's torrential downpoars to clean up the boat and also search the web for an appropriate knot to use for my genoa. Although experiences here seem to show otherwise, the consensus that I've seen on knot sites says that the cowhitch (or Lark's head) is an unstable knot when tension is applied to only one side. But it is so simple and compact that I didn't want to dispense with it.
There is a knot called the "Pedigree cow hitch" which tucks the standing end into the knot and makes it bind upon itself. As I have 2 sheets going to the ring I opted to tie 2 mirror image pedigree cow hitches with the additional refinement that the excess standing ends feed into each other, doubling the potential binding.
The result, even with my 18mm sheets is quite compact and I'm sure it will hold up well.
Zanshin is offline
post #45 of 56 Old 04-26-2007
poopdeckpappy's Avatar
Zanshin, (common whipping.) that's what she did, and if she remembers the bet, I out 500 bucks
hellosailor, I wasn't so reluctant to use the larks head because I needed to try something else besides the bowline and being a new sail, it needed new sheets and so I gave it a try......I will difineitly stay with the larks head
oh, and what I did was cropped that imagine to show only the Larks head, the wording " Prussik Knot " is for the knot imagine below the larks head............sorry, I suck at graphics
poopdeckpappy is offline
post #46 of 56 Old 04-26-2007
I'm confused. Are you used a single line for the sheets or two lines?
wumhenry is offline
post #47 of 56 Old 04-26-2007
that's for two sheets ( lines )
post #48 of 56 Old 04-26-2007 Thread Starter
Zanshin's Avatar
wumhenry - I posted an existing picture of the Pedigree cow hitch; imagine a mirror image to the left of that and the bitter ends each going into the turns of the other. I have 2 separate sheets, so needed 2 knots.
Zanshin is offline
post #49 of 56 Old 04-27-2007 Thread Starter
Zanshin's Avatar
I sailed today in 25+ kts of wind and the new pedigree cow hitch knots held up very well and didn't cause me any problems at all while tacking! I'm a happy camper - thanks to all in this invaluable forum!
Zanshin is offline
post #50 of 56 Old 04-27-2007
Good to hear it...
sailingdog is offline
Internal Halyards DWH Gear & Maintenance 9 07-14-2008 07:19 PM
Knot usage for sheets and halyards Zanshin Gear & Maintenance 8 04-25-2007 10:35 PM
Running Internal Halyards Dan Dickison Gear and Maintenance Articles 0 03-25-2002 08:00 PM
Wire-Rope Halyards Tom Wood Gear and Maintenance Articles 0 08-14-2001 09:00 PM
Samson Pre-spliced Halyards Dan Dickison Gear and Maintenance Articles 0 12-28-2000 08:00 PM
