04-27-2007
Puff—
Unless you are taking the mast down, I wouldn't recommend removing all of the rigging at once...
You will need to use two halyards to go up the mast, one for the ladder and one as a safety line, in case you slip and fall or the halyard supporting the ladder breaks, or the ladder breaks...
In theory, you could use a halyard to replace the shrouds on either side and one to replace the back stay, but I don't think I would do that, especially given that your mast has double lower shrouds on either side... and I don't think that those halyards would support the mast well enough for you to safely climb it.
Do it one piece at a time... and take your time to do it right.
