Icebox Drain - Page 2 - SailNet Community
post #11 of 11 Old 09-01-2008
Our icebox drain goes to a hose that ends just behind the companionway steps. I could leave the cap off the end and it'd just drain into the bilge. But I don't like water in the bilge, so I leave it stoppered. When I want to drain it, I drain it into a bucket and empty the latter over the side. (The water from two bags of ice requires two trips.) I plan someday to look to plumbing that drain into the sink drain if I can. (Might not be able to do that, as I suspect the bottom of the icebox is below the waterline.) If I do it, I'll probably put a valve in it. Cold water is better than no cooling at all.
Jim
SEMIJim is offline
Source for Oil drain plug bestfriend Gear & Maintenance 6 01-25-2007 07:40 PM
Oil Drain Universal M18 MBesant Gear & Maintenance 3 07-12-2006 08:40 AM
Insulating an Icebox SailNet Gear and Maintenance Articles 0 07-22-2002 09:00 PM
Ice box drain tube lgsailor52 Gear & Maintenance 4 05-22-2002 09:44 AM
