04-30-2007
Best Looking Moderator
Dremels are helpful, but you can really burn through the cutoff wheels.
I think this is related, but here is a generality I have learned in cruising and living aboard:
It would seem to make sense to only buy battery operated items. THat is what I did last time. However, that was a mistake because you really do not have the space to plug in the big batts. If you have multiple battery operated items (drill, dremel, etc), they will take the place of more essental items (like a handheld vhf or spot light... which are better if they are not the battery type, incidentally). So what happens is that you never have a tool when you need it.
But everything that needs 110. No 12v or battery operated. You can either run a generator or inverter to run them. With a couple of extension cords, you will be happier. The only exception might be going up the mast unless you have enough extension cords to reach there... which is worth considering when you plan you stock-up.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
