Old 04-30-2007
welshwind's Avatar
Re-Member
welshwind is on a distinguished road
Cause of stain losing its pigmentation?
I have a strange situation. In the galley below the sink and right above the flooring, the stain has lost its pigmentation. The varnish does NOT APPEAR to be damaged - it is not flaking or appear cracked. However, the rest of the woodwork is this nice cherry color and this area (about 24" X 3") is much more blonde.
Thoughts? Remedies? I'm thinking I'm going to have to sand it down, re-stain and re-varnish. I prefer to know what caused the issue first so I can prevent it from re-occurring.
Thanks.
S/V Benediction
Beneteau 36CC
"To reach the port of heaven, we must sail sometimes with the wind and sometimes against it - but we must sail, and not drift, nor lie at anchor.”
- Oliver Wendel Holmes
Old 04-30-2007
johnr
jr438234606 is on a distinguished road
It sounds like the varnish has separated from the wood underneath in that spot. This always causes light spots, even if the varnish is not flaking away. Water penetrating the wood can cause this separation. Is your galley sink leaking? If that's the case, the only way to make it go away is to remove the unbonded varnish and re-apply. On the other hand, if it were me, I would go back with formica/laminate.
Old 04-30-2007
hellosailor's Avatar
"below the sink "
Water leak carrying water and bleach into that wood from above or behind?
Or heavy sunlight that stripes just that section, bleaching it from UV?
Either way, wood and stain don't just "go blond", it takes UV or chemicals to change the color. If you really want to fix it you'll need to figure out the culprit first. Only then, strip and restain and reseal.
Old 04-30-2007
Welshwind-
This is definitely a situation where a photo would help.
Old 04-30-2007
welshwind's Avatar
Re-Member
Thanks - The photo is a good idea. Unfortunately, I won't be up at the boat for a bit (kids' soccer and volleyball always get in the way :-)
I'll take a picture and post, but it likely won't be for a couple of weeks.
Thanks for the thoughts.
S/V Benediction
Beneteau 36CC
Old 04-30-2007
camaraderie's Avatar
moderate?
Water damage is my guess.
Old 04-30-2007
Nahhh...stains and blemishes...normally Liver diseases...
Stay off the boose.....get your liver checked
Stays .. Losing Your Mast ... wind_magic Seamanship 50 10-21-2007 01:07 PM
Catalina 36 1987--Interior teak stain? bluemagic Catalina 9 08-30-2006 07:02 PM
Rust stain on sail... Jack Tar Gear & Maintenance 8 04-12-2006 04:25 PM
stain teak rails mroskothen Gear & Maintenance 3 07-26-2003 05:15 PM
Sail Rust Stain Removal davidusvi Gear & Maintenance 2 02-06-2002 03:59 PM
