Old 04-30-2007
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Straightening a Boom
Noticed that my boom has a slight rise and bend to starboard as though it stuffered a violent gybe, the boom is 2.25" x 3.00" x 11'.67", tear drop profile
Forespar asked me to bring it down to see what they can do; Do you think this can be straightened or should I bite the bullet and get ahold of Dwyer and replace it ?? ( 379.00 )
It is a slight bend in both directiond ( up and out ) but noticable when sighting down the length
Old 04-30-2007
Damn that's a small boom. The only problem with straightening a boom is that may weaken it. You might want to see about getting a slightly heavier boom, considering this one bent as it has. It can't hurt to have Forespar at least look at the boom though. Did it bend at a fitting or in the middle of the spar, where there is no hardware attached??
Old 04-30-2007
PDP...
Of course you can straighten it some...that lenght and shape and thickness will do it...
I would straighten it, no problem...done that many times (except last time ehehehehehe)
Just be carefull when you do it, and avoid "starightening" all to soon and too fast. Do small portions at a time...That's what Saprcraft and others do.
The get it jammed and bend it....
Go ahead, gentle but firmly, use a steel baclony frame or something you can use to do leverage
you're OK
let me know.
Old 04-30-2007
LOL, yeah it's a small one, it's off a 69' Islander excaliber
This was my concern and also my next question if someone was to bring it up;
Can it be reinforced from the inside, the only reason I would go this route is that the grooseneck and outhaul cap are era dated, the style would be impossible to replace
Considering this one bent as it has. It can't hurt to have Forespar at least look at the boom though.
agree, can't hurt
it appears the bend starts at the vang plate
Old 04-30-2007
Sorry Giu, I didn't see your reply, I was working and sailnetting at the same time, I didn't realize it took me 30 mins to write a post......LOL
Thanks for the info, I feel a little better about it now; I'm trying to keep the hardware as original as humanly possible and the lastest extrusions just don't fit what I have and the lastest hardware doesn't fit the era, so I was kinda bumming about replacing the boom & Hdwr
Old 04-30-2007
I wouldn't even bother starightening it unless its too far bent.
Send a photo, sometimes its so minor that its not worth it. You can allways let it be till it fails...
Old 04-30-2007
PDP-
He should know... Since he's the resident expert on boom breakage...
Old 04-30-2007
My wife says the same thing, we've been sailing with it since we bought the boat 10 month ago,so why worry over it, and it probably isn't a big deal to let it go, it's just I know it's bent and that in itself bugs.
Old 04-30-2007
If it doesn't interfere with sailing the boat... ignore it until it becomes either unnoticeable or a raging obsession, in which case, you'll just replace it...
Deadly Serious about Booms John Rousmaniere Seamanship Articles 0 10-12-2004 08:00 PM
Control the Wicked Boom John Rousmaniere Gear and Maintenance Articles 0 05-06-1999 08:00 PM
