Old 04-30-2007
GotTheNotion is on a distinguished road
Old Fiberglass Deck Deterioration...HELP!!
I was taking the rubrails off my new to me 1970 P-23 this morning. When I got done I had fiberglass all over my legs from laying down on the deck working. I had to use tape to get it off....duct tape works the best by the way.
Anyway, is there anything I can do to seal the deck so this doesn't happen anymore?
Thanks for the help CliffL, nice kicks to the boom traveler. I am intrepid.
Old 04-30-2007
What do you mean by fiberglass all over your legs?
If you're talking about a whitish powder, that is probably oxidized gelcoat, and you can re-gelcoat the hull in those areas or paint over it after sanding it down to a solid gelcoat.
If you're talking tiny glass fibers, then you probably have damaged laminate, and really need to sand it and re-coat with resin and then either gelcoat or paint over the resin.
Old 04-30-2007
camaraderie's Avatar
moderate?
My guess is that it is oxidation...compound the deck and wax it before resorting to more drastic solutions.
Old 04-30-2007
Thanks guys!
I like trying to compound and wax. I did realize this afternoon, when finishing the port side that I was laying on a hatch that is nasty old fiberglass and should be replaced. I think that is my culprit.
Old 04-30-2007
itches like a bastage doesn't it..
Old 04-30-2007
CliffL is on a distinguished road
Was there to help
You've heard, "blind leading the blind"
Well I was over at GTN's today to help remove the rub-rails...she did complain of having fiberglass on her legs...I volunteered to help remove said intruders...no luck.
Cliff
Old 04-30-2007
Yep.. duct tape really does take it off.
Old 04-30-2007
CliffL there's always tomorrow...and that is a straight up lie.
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
