04-30-2007
ST 60 Wind Instrument
Ok, looking the something easy I am missing.
Splashed the boat today and stepped the mast. We were very careful with all electrical connections but did not check everything before we stepped the deck stepped mast. Everything works just fine ( VHF, All lights) EXCEPT the ST 60 Wind. All I get is a 0.0 and then a dotted line.
Have never had the problem before. First, pulled the Navpod and checked connections at the back of the instrument because I had it off to send my Auto Pilot back to Raymarine and wanted to make sure I did not disconnect something. That would have been the easy fix.....all looks fine. Tomorrow, weather permitting, someone will go up the mast and make sure the connection is fine there. It can only go in one way, I have done it for 4 years and it was fine, but it is the next easiest fix and hopefully may be the answer.
The last place I can see, and that is why I hope someone here has an answer, is the connections made INSIDE the deck stepped mast. Yep, would have to pull it again. I watched it being connected and would swear he did a good job....but?
Any quick fix ideas out there?
Thanks,
Tom
