Old 04-30-2007
CliffL is on a distinguished road
Stupid newbie question of the day
The valve under my sink is stuck in the open position. It actually won't budge. I was told that I need to replace the valve. A guy I've befriended told me the best and simplest way to replace the valve, was to take apart the thru hull, replace the hose and valve, then put a new thru hull in place of the old one. He said that this would actually be easier than trying to remove the valve from the hose in its current location. He also said it's how the folks at his shop would make the repair if I were to hire them. Hmmm. Sounded odd to me...but in a way, it kind of made sense (in that "hmmm, YGBSM" way. It also sounded really easy when he was explaining it, but like all things I've never done before, I'd rather watch the first time. If I do decide to replace the thru hull...how does one go about taking apart the old one...he said something about grinding it off from the outside and it simply pops off. I have a feeling I'm in for a big $urpri$e. Any ideas? Help
Cliff
Old 04-30-2007
sailortjk1's Avatar
Can't help, but I'm sure others can.
I will say that replacing a thru-hull is anything but a stupid newbie question. Its something that must be done carefully and correctly.
Are you sure you can't just replace the ball valve?
Removing the thru hull and rebedding etc., sounds like a lot of work for a bad valve.
Old 04-30-2007
camaraderie's Avatar
moderate?
Assuming the through hull is in good shape...there is no need to remove it.
Remove the hose from the sea-****...unscrew the sea-**** from the thru-hull (that's the hard part...may require penetrating oil and/or heat to loosen)...and then screw on a new one. If that doesn't work...you may need to grind out the entire through hull.
Old 04-30-2007
Is this "valve" a seacock that is physically attached to the through hull or a diverter valve?
Through hulls require you to haul the boat out to replace them as a general rule. They screw together and to take them apart you need a big flat to unscrew the outside part of the through hull from the inner part.
Unless this is a seacock, there is no reason to remove the through hull to replace it. You may have to replace some of the hoses, but should be able to remove the valve fairly easily. The way I would recommend you do it is to pour really hot water into the valve and see if that frees it up first. If it doesn't then the valve needs to be replaced.
A quick and dirty way to do it, if you have to replace the valve, you can probably cut both of the hoses and then replace one of the hoses with a new one, that is long enough to compensate for the reduced length.
Old 04-30-2007
Thanks for the quick replies
I like the idea of running very hot water thru the hoses to see if that frees up the valve. If that doesn't work, I'll try to replace the valve from inside...rather than taking apart the thru hull. If I simply can't budge the think, I'll hire someone to take apart the thru hull...and I'll watch and learn. The boat is currently on the hard so it's a good time to do the job. Also...a follow-up question...
...How does one service the other valves. They are all ball-in-socket types. How do I lube 'em, and what's best to use? OK, so this may be kind of silly...but I thougt about using long q-tips with some sort of lubrication applied on the tip, and going from the outside thru the thru-hull...while someone inside the boat works the valve back-and-forth.
Thanks again
Cliff
Old 04-30-2007
Sailingdog...
I think it's a seacock...but I'd have to go check it again.
Cliff
Old 04-30-2007
You can lube them from either the inside or the outside.. outside is easier, especially if the boat is on the hard ATM. Anhydrous lanolin or lanocote can be used to lubricate the seacock ball valve, and works fairly well.
You really need to lubricate them about once every six months and you need to work the valves at least once a month, to prevent them from freezing in position.
Old 04-30-2007
GotTheNotion is on a distinguished road
Hey CliffL thanks for the quick reply to questions. Hope to see you tomorrow for help.
Old 05-01-2007
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
if its a plastic thru-hull be VERRRRRRRYYYYYYY careful when you apply that big-azz wrench to the valve.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 05-01-2007
Removing the valve is really really easy to do...hold valve with one hand, your choice of hand is important.
Then with the other hand, remove boat from around the valve.....
Newbie question - sail terminology blueranger Learning to Sail 5 03-17-2007 07:30 PM
Newbie question regarding Seacocks Marlinspike Learning to Sail 7 08-14-2006 02:02 AM
Newbie to Sailing has a boat question... marinesniper Boat Review and Purchase Forum 7 08-05-2006 10:09 AM
Stupid engine question sneuman Gear & Maintenance 8 04-24-2003 04:25 PM
Newbie question Joe206 Learning to Sail 13 01-17-2002 10:12 PM
