British Seagull? Dinghy engine advice needed - Page 2 - SailNet Community
post #11 of 26 Old 05-02-2007 Thread Starter
Pamlicotraveler's Avatar
Good info all....Weight to horsepower seems to increase between 5&6 hp and then seems to level out.
Mercury weights (from Defender site) 2.5hp is 28lbs, 3.3hp 29lb, 5hp is 45lbs, 6hp 73lb!, 8hp 73lb, and 15hp 77 lb.
SD-What I saw said your 3.5 Tohatsu is 41lb. That's manageable...Its that jump into the 70's that hurts.
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #12 of 26 Old 05-02-2007 Thread Starter
And built in gas tank is another big thing. If you are motoring 200 feet who wants to set up and prime a gas tank.
post #13 of 26 Old 05-02-2007
Swabbie
Neises's Avatar
A couple nice features to look for: Throttle control on tiller, and neutral gear.
The Mercury 6 has an alternator, probably explains the jump in weight from the 5.
Pete
Expo Solar Sailer
Neises is offline
post #14 of 26 Old 05-02-2007
Best Looking MALE Mod
Cruisingdad's Avatar
They make lightweigth 4-strokes, but I cannot remember the weight. Also, as was mentioned earlier, the throttle placement and gear placement is a big deal. I am not sure if your tender can plane, but if so, the extra HP could be worth it.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #15 of 26 Old 05-02-2007
RichH's Avatar
British seagull or small Evinrude or even a 'cruise n carry' (Shindaiwa) will work. The secret to keep these small engines running is to run the carburator fully dry **each** time you shut down .... never ever let gasoline 'sit' in the carb for more than a few hours. When storing for long term remove ALL the gasoline mix, open the main jet and squirt in a little isopropyl alcohol.
Other than that both the water cooled Seagull and the Evinrude dumps the cooling water down the mainshaft ... which requires that you disassemble the powerhead from the shaft every 6 months or so to regrease the splines in the crankshaft nose ... if you do this and the above the will last 'forever'.
All the 'small' outboards require clean and FRESH (less than a month old) gasoline ... do that any will have 'nary a problem. Never ever let gasiline sit in a small outboard for more than a month and ALWAYS run the carb dry every time you shut down.
RichH is online now
post #16 of 26 Old 05-02-2007
T37Chef's Avatar
Honda 2HP
I have come to really like our HP (26.7 lbs) Honda 4 stroke. It has an internal tank and throttle on the tiller. It takes a bit to get used to operation, no reverse (the engine turns 360+ degrees) or that the prop engages when you increase the throttle. Heres a link to it...
Honda BF 4-Stroke Marine Outboard Engine - 2 HP Motor Specs
The motor came with the dingy when we purchased it, initially I wanted to increase to a 8-9 hp, but I have got used to going slow and joy the ease of putting it on the dingy with one hand behind my back
Anyone had luck with these electric motors?
Torqeedo Electric Outboard Motors | Navagear.com
Shawn
T37Chef is offline
post #17 of 26 Old 05-02-2007
tdw
Super Fuzzy Moderator
tdw's Avatar
There are many things the British do that are admirable. Making engines is not one of them.
Seagulls are in fact held in high regard by corduroy trouser wearing anoraks (with elbow patches) who actually know what is meant by sheerstrake, oakum and pitch and who even know their intended use. Brave souls who take cold baths in the winter , wear woollen underpants, swear by a gaff rig and consider everything that has happened post Disraeli to be a retrograde step with the possible exception of Margaret Thatcher.
If your concept of cutting edge technology is a 1948 Morris Minor then Seagull is your kind of motor.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #18 of 26 Old 05-02-2007
I like it, and it will run about an hour on the 1/3 gallon in the built in tank. I wish it had an option for an external tank, but it doesn't. I believe that the small Mercuries are actually made by Tohatsu at the moment.
sailingdog is offline
post #19 of 26 Old 05-02-2007
tdw
tdw's Avatar
Sd,
How old is your engine ? We were looking at a small 2 stroke outboard earlier this year and I'm sure (but cannot quote you model numbers) that we looked at botha tohatsu and a mercury both of which had built in tanks but could also take an external.
― Terry Pratchett.
tdw is offline
post #20 of 26 Old 05-03-2007
Originally Posted by tdw
Sd,
Brand new... just got it... believe it is a 2007 model. However, it is a four-stroke... that may be why it doesn't have an option for an external tank, since four-strokes are considerably more fuel efficient than two-stroke engines are.
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-11-2004 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
