Old 05-04-2007
johnr
jr438234606 is on a distinguished road
Engine Zincs
I want to inspect and replace the zincs on my Perkins 4.108 diesel. I'm trying to determine where the zincs are located. My Perkins manual doesn't refer to them. Any advice?
Old 05-04-2007
camaraderie's Avatar
moderate?
Should look like a hex nut on your heat exchanger.
Old 05-04-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Most heat exchanger pencil zincs look like this -
True Blue . . .
sold the Nauticat
Old 05-04-2007
SailinJay is on a distinguished road
Some of them may be only one piece, with the zinc firmly attached to the hex nut.
Old 05-04-2007
Alden68's Avatar
Armchair Horn Sailor
Alden68 is on a distinguished road
I have a 4-107, could there be two of these nuts? and are they located on the top of the heat exchanger?
Old 05-04-2007
gc1111 is on a distinguished road
My Westerbeke, which is a Perkins 4-107 in disguise, has one zinc in each of the main heat exchanger and the oil cooler exchanger. If you have not changed them for over a year, they might have completely disintegrated.But the previous photo should help you determine if the thing you remove is, in fact, a zinc holder.
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
