Odd coolant leak issue - Page 2 - SailNet Community
post #11 of 13 Old 05-08-2007 Thread Starter
Valiente's Avatar
While the expansion tank contents fluctuated yesterday during an hour-long run at cruise speed, it didn't go above "max" or below "add". I, on the other hand, added a hose clamp to the tank barb...a likely culprit, I think, for the original loss of coolant.
I will monitor this, however and will likely have the entire cooling system/heat exchanger pressure-tested just in case. I will also examine all petcocks/drains and hoses for tiny leaks.
I would've done this yesterday, but I was a tad preoccupied (see "gravity versus boat" thread...) in General Discussion.
Thanks for the responses!
Valiente is offline
post #12 of 13 Old 05-08-2007
Yes, running home to put on a pair of clean shorts will eat up a bit of time... so will stopping by the ER to get your heart restarted.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #13 of 13 Old 05-08-2007
you may be able to get a loaner pressure tester from oreilly auto parts, they're real nice about loaning tools. (they have a program)
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
Odd Boat Names sailingdog General Discussion (sailing related) 91 12-07-2013 11:07 AM
coolant loss troubleshooting recommendations? mrkeith Gear & Maintenance 38 05-08-2007 04:20 AM
Exhast Leak / Wrap Material? 1970Columbia34 Gear & Maintenance 11 05-01-2007 05:19 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 01:41 AM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 09:00 PM
