05-24-2007
How thick are the bearings... .what is the difference in the diameter of the shaft compared to the hole? Also, do you know if the center portion of the tube is supported well enough and of sturdy enough construction to take forces from a bearing located there? In many boats, the most significant reinforcement of the rudder stock sleeve is at the top and bottom, so the bearings are usually located there.
