Blogs
User Name
  #11 (permalink)
Old 05-08-2007
txmatt's Avatar
txmatt txmatt is offline
txmatt is on a distinguished road
Originally Posted by tenuki
So on stainless vs aluminum rivets, it sounds like here are the pros/cons
aluminum - pro: easier to rivet, no galvanic corrosion, easier to drill out
cons: less shear and tensile strength
stainless - pro: better sheer and tensile strength
cons: hard to rivet, galvanic corrosion, impossible to drill out
You should be able to drill out stainless rivets.
Matt
Kittiwake 23
  #12 (permalink)
Old 05-08-2007
tenuki's Avatar
tenuki tenuki is offline
Helms ALee!
tenuki will become famous soon enough
why not just pop in an aluminum rivet to cover old holes instead of epoxy?
  #13 (permalink)
Old 05-08-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Tenuki-
Pop rivets have a tiny hole in the center, where the mandrel is located... not water tight. Also, do you want your boat to look like a junkyard reject... and it adds windage and weight aloft.
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
  #14 (permalink)
Old 05-08-2007
poopdeckpappy's Avatar
poopdeckpappy poopdeckpappy is offline
Senor Frog
poopdeckpappy has a spectacular aura aboutpoopdeckpappy has a spectacular aura about
IMO, anything that going to take a stress would be drilled, tapped and screwed and there really should be that many items, everything else could be rivited with aluma, alou min, a-lou - me, ah f**k it, not stainless
  #15 (permalink)
Old 05-08-2007
tenuki's Avatar
Helms ALee!
Tenuki-
Yes I do, it's my cheap ass security system..
  #16 (permalink)
Old 05-08-2007
PDP-
In many cases, rivets are actually stronger than the screws would be, when connecting hardware to a mast. Most of the times the only threaded surface bearing the loads for a machine screw that is attached to a spar are the four-or-five courses of threads in the wall of the spar itself...which isn't all that thick. A rivet is held in place by the peened over section that the mandrel mushrooms out... and that, plus the fact that the diameter of the end of the rivet is larger than the hole generally give it a good deal of support. The main reason to use screws over rivets when adding hardware to a spar is if the hardware needs to be easily removed for servicing or replacement.
For instance, I used 3/16" stainless steel rivets to attach several small padeyes to the spreaders on my boat.... I don't see any need to remove them or repair them...there's really nothing on a padeye to break or service. For the line clutches and winches, I used screws. However, I would bet that the two SS 3/16" rivets would support as much weight as the five or six screws used to hold the winch to the mast.
  #17 (permalink)
Old 06-03-2007
tenuki's Avatar
Helms ALee!
Ok, I'm knee deep in this project now, things going ok. One question:
The previous owner apparently liked stainless steel 'sheet metal' self tapping screws. They seem pretty good actually, I've removed a bunch of them to exchange out some sheeves and I think I'm gonna go this route for the main mast shaft instead of rivits unless it's something I'm not gonna move ever. btw, the old rivets were aluminum, so I'm guessing that would be ok to use for most of my stuff too. The aluminum rivets drill out so easy I'm temped to use them for everything to cut down on galvanic corrosion....
The mast head is pretty thick aluminum, so anything I got to put on there (antenna) I'm gonna drill, tap, and use ss screws. btw, I saw this on another forum, anyone ever use
Rivet Nuts and Threaded Inserts, avk nuts, ribbed L rivets nuts, ribbed K rivet nuts, half hex rivet nut, flat head rivet nuts - Jay-cee Sales & Rivet Inc.
there is something similar sold under brand name RivNut
  #18 (permalink)
Old 06-03-2007
I'm not a big fan of self-tapping screws, especially for use in aluminum spars, since the threads aren't as strongly formed as those made with a proper tap, and the material is relatively thin to start with...so each thread has much more affect on the grip of the fastener.
The Rivet Nuts look like a pretty good solution. It looks like the stainless steel ones are custom order and may have a fairly high minimum number to order. I am curious as to how much the tools and fasteners cost.
  #19 (permalink)
Old 06-03-2007
Boasun's Avatar
Boasun Boasun is offline
Boasun will become famous soon enoughBoasun will become famous soon enough
Question
This looks good. But do need a surveyor or N.A. report on them. Or someone who has field tested them on their own boat.
The mast manufacturer's feelings about them?? Some one!?
Display Modes
vB code is On
Rust Removal from Tools svzephyr44 Gear & Maintenance 2 09-24-2003 07:42 PM
Feature: Safer Outboard Engine Removal and Installation Our Readers Write Miscellaneous 0 12-09-2002 08:00 PM
Putting the Right Tools On Board Don Casey Her Sailnet Articles 0 10-24-2002 09:00 PM
Rivets Tom Wood Gear and Maintenance Articles 0 08-20-2000 09:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
